pop corn
Re: pop corn
Postby Dnderhead » Thu Jul 16, 2009 4:41 am
If you are going to try either corn or oats . I whould suggest starting with a thin mash like 1 pound (1/2kg) to the gallon (4L)
then work your way up. you can always add sugar.
Dnderhead
Master Distiller
Re: pop corn
Postby Fester » Thu Jul 16, 2009 4:50 am
Dnderhead wrote:If you are going to try either corn or oats . I whould suggest starting with a thin mash like 1 pound (1/2kg) to the gallon (4L)
but i would never know if my mashing skills (?) are good if i add sugar. it would always be just another UJSM
Fester
Re: pop corn
Postby Dnderhead » Thu Jul 16, 2009 5:37 am
not hard to tell ,,,after mashing ,1LB per gal you whould have OG of 1.03. and do a iodine test. that whould be about 3% abv.
then add sugar to make up the difference.to git a decent run.
as : mash 1 lb grain = 3% (after mashing check for conversion ,then)
add 1/2 lb sugar = 4%
total = 7%
this way you will git your practice and not wast your efforts /mash.
(this should turn out something like UJSM) if all goes well ,, next time convert more grain and add less sugar
Dnderhead
Master Distiller
Re: pop corn
Postby pumpman » Thu Jul 16, 2009 12:14 pm
Thats what I want to work up to is a complete corn mash. After I get more time in of corse.
pumpman
Re: pop corn
Postby violentblue » Thu Jul 16, 2009 9:32 pm
Trust me when I say enzymes are your friend. I've done many all grain mashes. and never has one gone wrong when I've used enzymes.
Just put an all barleyu malt down, I added enzymes just to be sure.
I've found using alpha and Gluco amalese there is much mor forgiveness than using malt. that being said, malt has the flavour that you want, but the enzymes keep it all from being a waste of time.
violentblue
Re: pop corn
Postby Fester » Thu Jul 16, 2009 9:50 pm
violentblue, where do you buy your enzymes from?
Fester
Re: pop corn
Postby violentblue » Fri Jul 17, 2009 5:47 pm
mile hi
violentblue
Re: pop corn
Postby MuleKicker » Mon Jul 20, 2009 4:36 pm
Fester wrote: But packing my bags now cause I leave for a 3 week excursion in a couple of days and i don't have anything fermenting for the first time in a long time. That feels a little weird.
Fester
Fester!, I am ashamed of you............. You know better than that!
-Control Freak-
AKA MulekickerHDbrownNose
MuleKicker
Re: pop corn
Postby I-GOR » Tue Jul 21, 2009 11:43 am
arc1000 wrote:New ground here; embolden by amylase 'stead of malting, so next wash will be feed corn, air popped covered with water then set the enzyme on it. Has any one sourced the Aspergillum oryzae fungus that gets note in the parent site.
Bujapat's thread on his sake experience over on the recipe development page goes into the use of kome koji (pronounced co-may co-jee). Also been discussed a couple places elsewhere, Uncle Remus rice alcohol...........etc.
viewtopic.php?f=11&t=2427#p6700267
I-GOR
Re: pop corn
Postby Fester » Thu Jul 23, 2009 2:04 pm
it is hot as hell in Texas. just look what happened to my deer feeder!
Fester
PreviousNext
Return to Grains
Who is online
