How the ^&$@ do people grind their grain?
Postby peanutaxis » Wed Mar 21, 2012 10:01 pm
I am using a drop through coffee grinder, but no matter what I do everything gets clogged when I try to sparge. Last time I went really coarse, and it was worse!
help
really pissed off
thanks
peanutaxis
Re: How the ^&$@ do people grind their grain?
Postby Prairiepiss » Wed Mar 21, 2012 10:44 pm
What grains are you using? The coursest setting on mine is still too fine? Little more info on your setup would be nice. I use a roller grain mill. Started out using a blender.
It'scoldaroundhere. Whenyouloseyourjacket.
My Stuffs.
Prairiepiss
Master Distiller
Postby rtalbigr » Thu Mar 22, 2012 5:00 am
Although I haven't used this method, I just don't have the facilities to do it, some are now grinding the grains very fine, even to flour and using the boil-in'bag method. Ya might want to do a little research there.
Big R
rtalbigr
Postby Barney Fife » Thu Mar 22, 2012 5:09 am
You need a grain mill, not a coffee grinder.
I use a cheap "Carona" mill. I took off the handle, bolted on a pulley, and using double-reduction, slowed it down to about 50 rpm, and it does great with an old 1/2hp motor.
I just searched real quick, and they can be had for around $25.....
http://www.amazon.com/Hopper-Cast-Grind ... 657&sr=8-3
Barney Fife
Postby King Of Hearts » Thu Mar 22, 2012 5:44 am
peanutaxis wrote:I am using a drop through coffee grinder, but no matter what I do everything gets clogged when I try to sparge. Last time I went really coarse, and it was worse!
help
really pissed off
thanks
What equipment are you using for a false bottom if anything?
Brewhaus 2in Pot Still head, 15.5 gal keg, 4 inch 5 plate copper column, deplag & condensor
A bad wash never makes a good whiskey
and a good whiskey always starts with a good wash.
King Of Hearts
Postby peanutaxis » Fri Mar 23, 2012 12:06 am
King Of Hearts wrote:What equipment are you using for a false bottom if anything?
Hi. Just using mutton cloth over holes drilled in a bucket. Even without the cloth nothing comes out!
peanutaxis
Postby peanutaxis » Fri Mar 23, 2012 12:13 am
rtalbigr wrote:Although I haven't used this method, I just don't have the facilities to do it, some are now grinding the grains very fine, even to flour and using the boil-in'bag method. Ya might want to do a little research there.
Big R
Oh! I'm using barley to make whisky. Can't find much on boil in a bag though.
p.s. Oh, you mean BIAB! THanks!
peanutaxis
Postby Washashore » Fri Mar 23, 2012 3:53 am
I use this thing with a power drill in place of the hand crank. I'm able to mill 55 pounds of grain in about 10 minutes.
EDIT: missing link
http://www.barleycrusher.com/view_image.php?img=bc_main
Washashore
Postby King Of Hearts » Fri Mar 23, 2012 4:23 am
help
really pissed off
thanks
Could you post a picture of the grind? I used a double bucket to sparge when I first started 25 years ago with no problem.
King Of Hearts
Postby maheel » Sat Mar 24, 2012 3:22 am
maheel
Postby peanutaxis » Sat Mar 24, 2012 3:19 pm
Washashore wrote:I use this thing with a power drill in place of the hand crank. I'm able to mill 55 pounds of grain in about 10 minutes.
EDIT: missing link
Ah, thanks. Does this give you any flour or is the grind quite even, because my problem is that I always get flour with the crushed stuff?
peanutaxis
Postby Washashore » Sat Mar 24, 2012 4:52 pm
Crushes very evenly...almost no flour. It's also adjustable so you can fine tune your crush.
Washashore
Next
Return to Grains
Who is online
Users browsing this forum: No registered users and 3 guests
