Cracked Corn
Cracked Corn
Postby *MoonShine* » Fri Oct 27, 2006 8:31 am
Is Cracked Corn, chicken feed, hog feed, all the same stuff?
*MoonShine*
Re: Cracked Corn
Postby Husker » Fri Oct 27, 2006 8:38 am
*MoonShine*:
I have heard cracked corn called "chick feed" or "chicken scratch". If you look at it, and all you see is cracked corn, and it smells like cracked corn, then I am pretty sure you can use it in the same manner.
As for hog feed, I could not answer. It may be corn, but have a lot of other things in it. If these things are simply nutients, then it will probably be fine. Hogs eat a lot of strange things.
However, if you can get "simple" cracked corn, then you know what you are starting with, and when things get added to it (by you), you will know exactly what is in the mash.
H.
Husker
Postby golden pond » Sat Oct 28, 2006 2:40 am
Cracked corn is just what it implies, corn kernels thats been cracked into pieces., nothing else added. It's best when it's 6-7 pieces per kernel. Chicken scratch feed is a much finer cracked corn and will contain powdered corn, it will work but will be harder to seperate the beer from it.The hog feed is powdered corn with other ingredients added and I would not use it for a mash. Cracked corn is no problem to find or buy or you can crack your own in a kitchen blender if need be.
golden pond
Re: Cracked Corn
Postby hornedrhodent » Sat Oct 28, 2006 5:09 am
What about popcorn - the sugar coating should be an advantage.
hornedrhodent
Cracked corn
Postby welska » Mon Oct 30, 2006 7:14 pm
We use cracked corn and re-grind it....since it has been broken once there are no stones and it's relatively clean.
Use a liquifaction enzyme to break it down and saccarify with a different enzyme.
Brian
welska
Re: Cracked corn
Postby Fourway » Tue Oct 31, 2006 9:33 am
that would be a great approach if you were looking to make vodka from corn, it's a surefire way to make lackluster whiskey though.
"a woman who drives you to drink is hard to find, most of them will make you drive yourself."
anon--
Fourway
Return to Grains
Who is online
Users browsing this forum: No registered users and 4 guests
