Making wheat malt.
Re: Making wheat malt.
Postby jedneck » Fri Apr 03, 2015 3:17 pm
Temp is controlled with a water heater thermostat that I had laying around and I can also open the damper on top to let heat out and move more air though it.
Malt was still soft with the roots dying up. A couple hours with a fan and it would have been able to go through my burr mill.
big help
Dunder
jedneck
Postby shadylane » Fri Apr 03, 2015 3:50 pm
I've read that once malt has dried enough it can take higher heat before the enzymes start to denature.
jed Post some more picts of your smoker/dryer
Edited: Please
Postby jedneck » Fri Apr 03, 2015 4:00 pm
Will do shady. Gotta wait till tomorrow for sum light. Its still a work in progress. I wanna add a fan and gotta build better trays. I just smacked this one together.
big help
Dunder
jedneck
Postby shadylane » Fri Apr 03, 2015 4:20 pm
That sounds like me. Make it with what I have, then use it.
The modifications will happen latter if the idea works out.
Postby jedneck » Sat Apr 04, 2015 5:29 pm
Shady I didn't forget about the pics. My smoke disided to donate my malt to the gods. The pan full of chops flared up and caught the tray on fire and it gutted the wiring. Gotta build a new one.
big help
Dunder
jedneck
Postby shadylane » Sat Jun 20, 2015 4:19 pm
Dangitman, Jebneck have you figured out how to build the new dry/smoker ?
On a side note, a friend just finish combining the wheat field next to me.
I've had too many malting failures from grain bought at the feed store.
Figure to store the wheat in the antique freezer in the shop to keep the bugs frozen.
Postby jedneck » Sat Jun 20, 2015 7:58 pm
Not yet but I gotta soon. I got 40ish pounds of corn that I wannna smoke with corn cob on a week.
big help
Dunder
jedneck
Postby Brutal » Sun Jun 21, 2015 10:09 am
Will it sprout after bring frozen?
Brutal
Postby Brutal » Sun Jun 21, 2015 10:13 am
Hey Jed I heard somewhere that you got angry, picked up that burned smoker, and threw it a long ways down into a Creek? With feats of strength like that we are gonna have to start calling you Jethro Neck lol!
Can't remember exactly where I heard about it right now...
Brutal
Postby MichiganCornhusker » Sun Jun 21, 2015 10:57 am
Brutal wrote:Can't remember exactly where I heard about it right now...
Must have been someone who seen where it landed... :shock:
MichiganCornhusker
Postby jedneck » Sun Jun 21, 2015 11:07 am
I will rebuild
Wander who that would be?
Till I get time to build one like this, i'm prolly gonna drag it outta the creek and use an old cast iron dutch oven an charcoal to heat it.
big help
Dunder
jedneck
Postby shadylane » Sun Jun 21, 2015 2:18 pm
Brutal wrote:Will it sprout after bring frozen?
Yes
Postby HDNB » Sun Jun 21, 2015 4:51 pm
dutch oven must be sumthin different there. around here thats what we call call it when you fart under the sheets and then pull them up over da wife's head!
Jed, do you have a link for the internal workings of that smoker? that looks like a project i'd be into. :thumbup:
now i drink for evil.
HDNB
Postby jedneck » Sun Jun 21, 2015 5:04 pm
Hdnb I don't have a link but ill try explainin it. You see the brick box on the ground on right side that is the fire box. Smoke goes across ground through brick tunnel to smoke house.
If you still.need help ill do a scetch for ya.
big help
Dunder
jedneck
Postby HDNB » Sun Jun 21, 2015 5:16 pm
so basically, you build a little fire in the mouth of the tunnel>>> the smoke goes thru tunel under the wood stack >>>>smoke fills smoke house>>>smoke vent s out top of smoke house??
is there any dampers? a cap off for the mouth of smoke tunnel where the fire is built?
is holding heat in important or is this cold smoker?
just put some wooden dowels in the smokehouse to hang meat from?
dirt floor?
HDNB
Postby MichiganCornhusker » Sun Jun 21, 2015 6:13 pm
There is a link on here somewhere for that smokehouse build and it's worth finding. It's a great build and explains everything along the way. Might be in the thread with all the smoked meats...
Edit: http://www.smokingmeatforums.com/t/1304 ... nstruction
MichiganCornhusker
Postby yakattack » Tue Jul 21, 2015 5:55 am
MichiganCornhusker wrote:There is a link on here somewhere for that smokehouse build and it's worth finding. It's a great build and explains everything along the way. Might be in the thread with all the smoked meats...
Omg seriously building one. Hello wish I was in the county and could make the fire double as a stripping fire :( would save in electricity and propane
yakattack
Postby shadylane » Tue Jul 21, 2015 4:10 pm
Have another #25 of wheat malt finished and dried. Cheated this time and used the metal storage shed roof.
Now that the malt is dry, I'll kiln it. Hopefully that will kill any wild yeast or bacteria that's waiting to ruin the mash.
I'm getting tired of funky mashes, even if the distillate is pretty good.
Postby jedneck » Tue Jul 21, 2015 4:15 pm
I got 50# that should be ready to dry in a day maybe two. I agree with you on the funky mashes.
Then I believe I'm going to start on oats.
big help
Dunder
jedneck
Postby midlife-u-turn » Tue Jul 21, 2015 5:26 pm
shadylane wrote:Have another #25 of wheat malt finished and dried. Cheated this time and used the metal storage shed roof.
I'm going to be doing some wheat shortly and any suggestions would be much appreciated. Can you expound on your kilning technique/procedure.
midlife-u-turn
Postby shadylane » Tue Jul 21, 2015 5:35 pm
jedneck wrote:I got 50# that should be ready to dry in a day maybe two. I agree with you on the funky mashes.
From my limited experience, grain with a husk such as barley or oats is the worst for funky mashes.
Corn and wheat aren't so bad.
Postby shadylane » Tue Jul 21, 2015 5:40 pm
A friend has a old oven that's been modified.
It was made for 240v but he runs it on 120v and uses a thermostat to control it.
It's slow to come up to temp but very accurate once it gets there.
Postby MichiganCornhusker » Wed Jul 22, 2015 6:48 am
midlife-u-turn wrote:I'm going to be doing some wheat shortly and any suggestions would be much appreciated. Can you expound on your kilning technique/procedure.
I'm new to the idea of "kilning" the malt. I just did mine in a regular oven. I put it about 2" deep in a big pressed foil roasting pan, I could fit 2 at once in the oven.
I just set the temp to about 300F and let it go. Check on it, and stir it up about every 15 minutes. As long as it's still damp it won't start to roast. Chew a little bit of it as you go, you will know when it starts drying out.
I toasted mine until it started to just change color. I may have lost DP, but I think it will make up for it in flavor. I'll probably be running mine with malted barley, so I won't need the enzymes from the wheat anyway.
MichiganCornhusker
Postby midlife-u-turn » Wed Jul 22, 2015 12:03 pm
Our temps here have been in the mid 90's or higher and we have very little humidity. I think I can dry outside pretty darn quick. I put some caramel malt in my last barley AG and I think it did positively influence the flavor. Maybe I'll try roasting a portion as well and go with a barley mix.
I'm a little concerned about malting in my garage right now due to the temps. I guess I'll just have to be diligent about keeping it turned so I don't get any mold growth.
midlife-u-turn
Postby MichiganCornhusker » Wed Jul 22, 2015 12:39 pm
midlife-u-turn wrote: I guess I'll just have to be diligent about keeping it turned so I don't get any mold growth.
I rinse mine once a day. Not sure if that's the best way, but keeps the mold away.
Once the malt is dry and crunchy, you can take some of it further and make your own "crystal wheat malt". I did this with about 5-10 pounds and it tastes like chocolate & coffee. Will definitely add character to a whiskey.
MichiganCornhusker
Postby shadylane » Wed Jul 22, 2015 2:41 pm
I've noticed when malting at 60 - 70f the grain germinates slowly and consistently.
Malting at 80 - 90f by the time some of it is over modified, some will be chitting and everything in between.
Postby jedneck » Wed Jul 22, 2015 3:09 pm
shadylane wrote:I've noticed when malting at 60 - 70f the grain germinates slowly and consistently.
Gonna agree with you. I have sprouts that average 3/4 the grain with some just over chitted to 4x grain length. This is so much easier in winter when the basement is cool and dry instead of cool and damp.
big help
Dunder
jedneck
Postby shadylane » Wed Jul 22, 2015 3:46 pm
The problem with malting in my neck of the woods, is the weather is never cool and dry.
During the rare times it's good for malting, it's terrible for drying.
Postby shadylane » Wed Jul 22, 2015 3:51 pm
Something I've noticed, fungus and mold starts on the dead seeds. The ones that didn't germinate and when squeezed a white milky stuff comes out of.
If the grain I'm using has seeds that can't germinate, the mold starts on them first then goes after the rest of the malt.
Postby midlife-u-turn » Tue Jul 28, 2015 8:19 pm
I got my wheat malted and I think it turned out pretty good. I turned it about three times per day and it appeared to malt pretty evenly. No apparent issues with the temperatures. I have it outside drying and the weather is supposed to cooperate so I'll be able to get it good and dry.
midlife-u-turn
PreviousNext
Return to Grains
Who is online
