Irish Whiskey Barley Question
I am going to try an Irish Whiskey but I am having trouble finding un-malted barley.
The local whole foods has "Pearl Barley" for $1.52 lb
The home brew shop has Roasted Barley, Barley Flakes and of course malted 2-row and 6-row
Can I use any of these?
Re: Irish Whiskey Barley Question
Feed store is the cheapest.
Roasted and such is malted and then roasted. Flaked barley is ready to rock, but feed store is cheapest.
SR
SR
If I use flaked, do I use it pound for pound vs whole grain?
Example... Does 1lb flaked = 1lb grain?
- Swedish Pride
yeah if you can find a feed store they are much cheaper, but you can use flaked if you rather.
I don't think the weight difference would be huge.
Don't be a dick
I have called 3 feed stores and none have it right now. Do I need to worry about any chemicals with what the feed store would offer?
Cant tell you about chemicals on barley specifically but propionic acid is common on feed store grains as a preservative. Its only added in an ammount to prevend DAMP grains from molding or mildewing, not in sufficient ammounts to inhibit fermentation. The chicken scratch im using now has it in it and ive taken it to 9 generations as a sugarhead for example.
Jbt
Jbt
Deo Vendice
Deo Vendice
You want untreated barley seed that will sprout.Bourbon_Greg wrote:Do I need to worry about any chemicals with what the feed store would offer?
Treated seed is supposed to be colored, for a warning.
As jb pointed out, Propionic acid is a food grade preservative
It only keeps the grain from molding
Why do you want unmalted barley? Its a pita just buy it.
I thought i was wrong once,
But then i found out i was mistaken.
Kill the women, and rape the men.
- frunobulax
Just use all 2 row. It will be a light clean Irish whiskey.
I posted THIS last week.
My one, and last, experience with flaked barley wasn't encouraging. It doesn't lauter well so it threw off my otherwise tried-and-true protocol. I'll not use it again.
Just get a lightly-malted 2-row and you'll be fine.
________________
