Torrified wheat. Anyone use it?
Posted: Wed Mar 22, 2017 2:56 pm
by Still Life
Got a deal on some torrified wheat and learned that beer brewers uses it for head retention.
What flavor does it lend in an all grain?
Re: Torrified wheat. Anyone use it?
Posted: Fri Mar 24, 2017 1:29 am
by Still Life
Bump?
With 6 Honey Bear Bourbons under my belt, I'm going to add it to the recipe for kicks.
Instead of 1lb. each of white, red and pale (3lbs. total)
I'll try 3/4 lbs. each of white, red, pale, and torrified (keeping 3lbs. total)
Thus a comparison can be made.
Hey, a grain bargain is made to take advantage and use up.
Posted: Fri Mar 24, 2017 2:46 am
by Swedish Pride
had to google it, so torrified wheat is rolled wheat or course cracked wheat.
It will add wheat flavour i suppose
, think makers mark have it in their grain bill.
think a few good vodkas are made with nothign but wheat, converted with enzymes out of a bottle.
I got 30kg of wheat that I'll try to made voddy out of, It's next on the list after a malted wheat.
Posted: Fri Mar 24, 2017 5:28 am
by Mikey-moo
I wanted to reply to this thread... but was too torrified.
Posted: Fri Mar 24, 2017 5:44 am
by Swedish Pride
that's an torrible post
Posted: Fri Mar 24, 2017 5:51 am
by Mikey-moo
I don't know wheat you mean...
Posted: Fri Mar 24, 2017 6:13 am
by Still Life
Mikey-moo wrote:I wanted to reply to this thread... but was too torrified.
I had to fight auto-correct all throughout this post
Posted: Fri Mar 24, 2017 7:36 am
by aircarbonarc
Wheat torrified ideas are we bringing to distilling
Posted: Fri Mar 24, 2017 8:44 am
by HDNB
for sure! i know of a couple. Canadian wheat is best for this imho, but there may be a few argumentative Russians out there.
Posted: Fri Mar 24, 2017 8:56 am
by aircarbonarc
It's very true, makes a good tasting, economical consistent product.
Posted: Fri Mar 24, 2017 2:29 pm
by greggn
Ketel One.
Posted: Thu Apr 13, 2017 6:04 am
by Still Life
Added the torrified wheat to a Honey Bear run, and then compared it to the straight recipe.
Blind taste: It neither added nor subtracted any discernible flavor.
Maybe why it's not well-known or overwhelmingly used. Live & learn.
Posted: Fri Apr 14, 2017 12:15 am
by Swedish Pride
sounds perfect for vodka then if it's not a dominant flavour
good as i have a bag or unmalted in the shed wating for me to make some voddy
Posted: Fri Apr 14, 2017 4:36 am
by pigroaster
I torrify barley all the time by misting it with water in laundry sprayer about 1 -2 oz per 5 pounds and then hot air pop it at 2 ounces at a time. I hold popper covered until I hear it popping then let it flow out the chute. On barley the result is a white puffed grain seed only along the split but the grain head is larger. I put the result in a brown paper bag lined with paper towels to take the harshness out when I use it to brew beer by rolling it through my mill with a .030 gap. This is a lot cheaper than purchased products. Have fun. Wear gloves if you have soft hands. Works like a charm.
Posted: Sun Apr 16, 2017 8:55 am
by Still Life
pigroaster wrote:I torrify barley all the time by misting it with water in laundry sprayer about 1 -2 oz per 5 pounds and then hot air pop it at 2 ounces at a time. I hold popper covered until I hear it popping then let it flow out the chute. On barley the result is a white puffed grain seed only along the split but the grain head is larger. I put the result in a brown paper bag lined with paper towels to take the harshness out when I use it to brew beer by rolling it through my mill with a .030 gap. This is a lot cheaper than purchased products. Have fun. Wear gloves if you have soft hands. Works like a charm.
Everything I read about torrified grain leads back to beer brewing. Thanks, pigroaster.
