Basic mash problem
Brooklyn1941
Basic mash problem
Post by Brooklyn1941 »
Today I attempted to make my first corn mash.
2.5 lbs cracked corn, 2.5 lbs flaked corn, 1.5lbs malted barley grain, boiledfirst then simmered in 2.5 gal of water for an hour.
The grains absorbed half the water and turned to a heavy mush. I added more water and under low heat dissolved four lbs of sugar. Tested the specific gravity to a low of 1.040.
What did I do wrong....?
seamusm53
Re: Basic mash problem
Post by seamusm53 »
If you boiled the malt its enzymatically dead (denatured) and none of your starch converted to sugar.
acfixer69
Post by acfixer69 »
Pick a tried and true recipe and follow it to the letter, that's why they are T&T. Chalk this one up to learning.
AC
Pesty
Post by Pesty »
what went wrong..
The answer is inside the mashing and fermenting section.
This is an open book test..
NcHooch
Post by NcHooch »
have a read through this thread ...maybe even twice (know how when you watch a movie the second time you always see new things?)
: http://homedistiller.org/forum/viewtopi ... 96&t=47488
NChooch
