gelantinization of corn - wort bag or not?
Postby seravitae » Thu Oct 02, 2008 4:50 am
Hi guys,
Just a Q to all the corn-cookers out there, i usually use a wort bag (nylon mesh bag suspended in wort cooker), i was wondering if it's suitable to gelantinize in this. Any experiences ?
seravitae
Re: gelantinization of corn - wort bag or not?
Postby Dnderhead » Thu Oct 02, 2008 6:14 am
I never tried a bag but if you go much over 1 lb ( 1/2 kg) a gallon it will git as thick as pudding.I do split conversion do half of the corn convert
then do the other. and by using the sparging water helps to bring up the SG.
Dnderhead
Master Distiller
Postby seravitae » Thu Oct 02, 2008 6:24 am
interesting. i have 3kg (6.6lb?) corn in the bag + topped the container up (25L capacity). Not sure the of the density of cracked corn, but id say just under 20L (5 gal) water.
I plan to ferment on the grain, so i dont think ill sparge.. I think i also need to make some equipment for proper mashing.. :)
seravitae
Postby Dnderhead » Thu Oct 02, 2008 7:01 am
that should work, but at 1kg to 4l it will fill the pot when it swells and is prone to burn.
Dnderhead
Master Distiller
Postby Hawke » Thu Oct 02, 2008 12:40 pm
If you are going to ferment on the grain, there is no need for a bag.
One pound per gallon is easier to mash, but it makes for a pretty low potential ferment.
Hawke
Master Distiller
Postby seravitae » Thu Oct 02, 2008 5:20 pm
actually, to be honest, i got really annoyed with the bag last night and threw it out. I'd rather ferment on the grain and not use the bag, it seems to interfere with gelatinisation. I'll just make a stirrer instead so it doesnt burn..
seravitae
Return to Grains
Who is online
