Question on flaked corn maze
Postby pro65 » Fri Jan 09, 2009 4:38 pm
I have several pounds of flaked maze and 6 row pale malt. My past exsperiance is on the first mashing you heat your water to 165deg and then turn off the heat and add 8.8lbs of flaked maze and stir it until it thickens. Then after it sets for a little time you add the malt and stirr and so forth.
My question is after the fermintation is complete and you rack it and you charge your still and make your run, could Iuse the back set left in the still when it gets down to 165deg to pour it over another 8.8lbs of maze to start another batch and just add enough tap water to bring it backup to the 25L starting point or would the ph be to low. I know i will still have to add malt and yeast but was just wandering if the back set idea would work.
If I can what benefits would this add? More flavor etc.
Thanks again guys.Derrell
Moonshine the flavor of the South.
pro65
Re: Question on flaked corn maze
Postby trthskr4 » Fri Jan 09, 2009 5:01 pm
I wouldn't use more than about a gallon in a 25L ferment but would use it most definately. The benefit is that it does get the ph into a range more accomodating to the yeast and it adds alot of flavor to the mash and subsequently the whiskey.
trthskr4
Postby punkin » Fri Jan 09, 2009 8:40 pm
I use about 25% backset, i believe i get my very best conversions and flavour with this method. just seems to work better, acheived a 1056 yesterday, which is about the best i've done. 8)
punkin
Master Distiller
Postby Dutchmancreek » Sat Jan 10, 2009 7:33 am
I'm with Punkin on this one. I always put backset back into the fermenter. I tried a higher percentage but down to about 25% seems to work best. The flavor is best after about 3 generations of backset. Just watch your pH.
Never take off your hat, never sign your name
Dutchmancreek
Postby Usge » Sat Jan 10, 2009 7:49 am
I think he's talkin' about using backset in his mash water to mash the next batch of corn....not putting it in the fermenter.
But, I think the answer to both is "yes". You can use backset to do either. I would stick to the amounts suggested though (about 20-25%). It lowers PH and makes things slightly more acidic....which can benefit either scenario. Too much backset would make the PH too low and you'd get bad conversion on your mash, and/or bad conversion in your fermenter as well.
Usge
Postby punkin » Sat Jan 10, 2009 10:33 am
Yes, 25% backset in my mash water (and 60% sparge water, thanks dunder)
punkin
Master Distiller
Postby Dnderhead » Sat Jan 10, 2009 11:54 am
What I do is take all the ideas that sound like the mite work,, try them , use the ones that work for you or a combination of .
you will fiend that some witch works for one mite or mite not work for you or it mite work grate.don't be afraid to try different things.
some very simple changes make a whould of difference.also beer/wine sites have some useful ideas/info also
Dnderhead
Master Distiller
Postby pro65 » Sun Jan 11, 2009 3:13 pm
Usge wrote:I think he's talkin' about using backset in his mash water to mash the next batch of corn....not putting it in the fermenter.
Yeah that is what I ment, if I took the back set straight from the still and let it cool to 165deg then poured my flaked maze in it and stired it until it thickened and then go from there.
It would just stop the process of having to boil water to 165 deg on the stove. I know that I would have to add tap or distilled water back in to keep ph right.
pro65
Return to Grains
Who is online
