I have a question about adjusting the PH of a wash as it progresses throught to completion.
This is my problem... I have noticed that as my fermination progresses to completion the PH of the wash gets more acidic,and has on occasion stalled out the fermentation with residual sugar in the wash.
My water normaly is on the acidic side - 6 to 6.5.
One wash I tested was at 2 - 2.5, using the ph strips you get for checking urine at the pharmacy.
I used good old soda bicarb, and the helped to return the wash to about 4.5-5 and the wash took off again.
But then I read here that you shouldn't add bicarb to your wash as you may end up with a blue wash. My wadh didn't turn blue but I want to knwo what I can use to knock down the ph if it gets too high.
I amdoing primarly a sugar/bran flake wash or else the DWWG. Both I like the end product.
I also add some nutrients which are 2 1/2 TSP DAP; one Vit B tab, crushed;1/4 tsp epsons salt; 2 tsp dried brewers yeast.
I alays invert my sugar, and usually added citric acid to the sugar and water as per the recommend amounts.
I just stated a new batch but didn't use the VIt B or cit c in the inverting process..
So far it is working like a hot dam. Any recommendations?
