Hi All
We are having an issue with proofing on our last 2 runs with BirdWatchers. Most recently, we did a striping run (60L) of BirdWatchers and then a spirit run. The ABV was 92-96% for most of the run. Our Heads and Tails were very defined. We collected in small jars, odorless and clear until tails appeared. Here is our issue. When proofing, we are coming up with a cloudy finish. We have used distillate from early, middle and towards the end with same results. We also tried proofing with TAP water, Filtered Tap water, both room temp and cold,(RODI) Reverse Osmosis Di-Ionized water at room temp. We are going to try distilled water today. Thanks for any help you can give with this problem.
Thanks again
FD
