Removal of sugar
Removal of sugar
Postby Eob » Tue Apr 03, 2012 9:14 pm
Hey All,
I would appreciate any assistance that can be given. I am trying to remove the sugar added to a vodka product to get back to ngs without it being improved. Im ok with removing both water and sugar as well just want to make sure what we get down to is not improving the ngs.
Thank you for the help
Eob
Re: Removal of sugar
Postby Husker » Wed Apr 04, 2012 4:36 am
Eob, are you a micro distillery (i.e. legal)? Most home distillers are not going to have access to sugar/flavored vodka as a stock material, and will not know the term ngs (especially on a first post).
As for your question, the only way to separate is through distillation. Water the product down to 30% or less (it likely is already), then distill. If you run it through a pot still, take no cuts whatsoever, you should end up with the equivalent to the original ngs, pre-flavor, but at a lower abv. NOTE, depending upon what flavoring has been added, that may carry over on the distill. It may require additional distills (water down, rerun), or it may require distillation in a column still to pull out just the ethanol.
Also, you have to be concerned about scorching (and possible foaming) of the sugar based material.
Husker
Return to Novice Forum Graveyard
Who is online
Users browsing this forum: Google [Bot] and 0 guests
