Last sugar wash I did a gerber equivalent, I used a baby porridge, started with 2.3kg sugar (inverted partly) in 12 litres water, from memory would finish at a little over 10%, decided not enough wash for my still so upped it with the last 700g sugar and another litre of water. should finish at around 12%.
After siphoning off the wash I figured nothing to lose, experiment time and threw 15 litres of cold water on the yeast cake, crushed up 6 weetbix, added a few dst spns of molasses, then dissolved 3kg of sugar in about 3l water and warmed it to steaming, poured that in, not a lot of activity next day so tipped in last of the yeast tin, perhaps 2 dspns .. on day 4? now and slow but consistent progress, around 1.015 this morning..
anyway, decided to just use fresh yeast in future, found the lowan supplier doctor provided this info on the yeast ..
since my overall aim is to produce max % in the least time with minimal effort and maximum hearts..I can suggest rehydration temps of 30C
Pitching 30-35C
pH of wort 4.5-6.0, suggest 6.0
Fermentation temperature 30-37C
Keep glucose levels up to maintain growth rates
Ensure good agitation and oxygen input into the fermenter when rehydrating
Monitor the ethanol concentration in the cooled wort as the yeast will start to die off at 12% ethanol with little activity seen above 17% "
so I have a couple of questions .. glucose, inverting all the sugar seems a waste of time and energy, considering making a starter though and inverting the sugar for that and then adding it to a plain sugar wash. good plan or just pitch yeast straight in and let it do its thing ? certainly seemed faster first run but a lot more effort involved.
in the interests of speed, am i better to aim for perhaps 14% or even 16% .. adding sugar in 2 batches to bring down the sugar peak the yeast has to deal with. tomato paste and cheap cereal for nutrients.
what I was thinking of is that to clear the wash at the end would it not be better to have the yeast die off due to the higher ABV, or let it trickle along at 12% for ages. takes as long to clear as to ferment, so can you clear it quicker by some means ? considering crazy concepts like say adding a big batch of bicarb soda or even caustic soda at the end and radically change the pH and murder the poor yeasties.
when the weather warms up here and I end up with 4 fermenters bubbling along then I will be happy to cruise along, but I like to experiment and want to try and get something like a 4 or 5 day 14% ferment going using bakers yeast..
crazy talk ?
