in the birdwatcher sugar recipe it says to use 18Kg sugar, 80L water, 225g yeast, plus tomatoe paste,
that works out to be 12.5g yeast per Kg sugar, 2.81g yeast per L water,
2.81g per L water = 12.645g per gallon water,
and after trying it this works great,
but
what i have read:
-if alcohol is in the 5% or less range use 2 g per gallon,
-if alcohol is in the 5 to 7% range use 3 g per gallon,
-if alcohol is in the 8 to 10% range use 4 g per gallon,
this match's up with my old recipe passed down from the old boy, which is 4 g per gallon,
this also works grerat,
it is said that higher than 4 grams per gallon will get you some sulfur flavors,
so why is the birdwatcher sugar recipe over 4 times the recommended amount of yeast, and why does it work?
what would happen if you ran the birdwatcher recipe at the rate of 4 g per gallon instead of 12.645 g per gallon?
are my numbers off? why all the extra yeast?
