Adding only a few grains of yeast?
Postby peanutaxis » Fri Apr 13, 2012 9:55 pm
So I was trying to make a 300ml starter culture and figured that I'd read the back of the packet of yeast and proportion the amounts down. So I added only a sprinkle of yeast grains, less than a gram, which should have been plenty for the 300ml of wort, and put it on the stirrer. But it didn't work, nothing happened.
Since then I have successfully started a starter culture of 300ml with about 2g of yeast, WAY more than it should need.
Why does this happen?
peanutaxis
Re: Adding only a few grains of yeast?
Postby astronomical » Sat Apr 14, 2012 4:39 am
It was probably working, but, not noticable... This happens often when you culture yeasts from beer bottles, too. It could take days to show serious signs of fermentation.
astronomical
Postby RumBrewer » Sat Apr 14, 2012 8:37 am
peanutaxis wrote:So I was trying to make a 300ml starter culture and figured that I'd read the back of the packet of yeast and proportion the amounts down.
I think you're missing the point of making a starter.
The point is to scale UP not down. You are trying to build hundreds of billions of yeast cells. Give your starter a healthy dose of yeast and plenty of oxygen!
Sure, you cal culture up a starter from a very small amount of yeast, that's how labs do it all the time. But we are not working in a yeast lab, and we don't have to start with a small culture. So DUMP that pack in your starter and get it going. You'll end up with a healthy colony of yeast that will get your ferment chugging along in no time.
Everything I do or say may or may not have really happened... or it may or may not be all bull shit!
Turning money into steam and likker 10 gallons at a time!
I just want Uncle Sam to be more like Uncle Jessy!
RumBrewer
Postby Prairiepiss » Sat Apr 14, 2012 9:11 am
Lag time?
Misshandled yeast/bad yeast?
Temp?
To few active yeast cells per gram?
Any number of things?
It's kinda like pitching a 6 gram pkg in a 5 gal wash. It has a longer lag time then if a starter was made with the 6 grams.
Now my question is why are you only using 1 gram? I understand you are trying to make a starter culture. But when a 6 gram pack of yeast is around a dollar. Is it really worth skimping to save 18cents?
Maybe I'm just understanding the point? Or the problem?
It'scoldaroundhere. Whenyouloseyourjacket.
My Stuffs.
Prairiepiss
Master Distiller
Postby rad14701 » Sat Apr 14, 2012 2:44 pm
Yeast is too cheap and readily available in most areas to be stingy... The size of the active colony is what determines lag time... Start with a large enough healthy colony and your lag time can be reduced to mere minutes which helps vastly in reducing the chance of infection...
Master Distiller
Postby peanutaxis » Sat Apr 14, 2012 7:14 pm
Okay, thanks guys. I'll use more - I was just following the instructions figuring that using too much might produce off flavours in the starter.
peanutaxis
Return to Yeasts, Enzymes, Fungi, Nutrients
Who is online
Users browsing this forum: No registered users and 2 guests
