trying a new yeast, Lalvin 71B-1122
Saccharomyces cerevisiae
it is a yeast for making wine and baking bread
any one have any luck with this yeast ?
I had a bakers yeast stall out, so i added nutrients and this new yeast. It took off after a couple hours and is chugging right along.
71B-1122
- MichiganCornhusker
Re: 71B-1122
I'm making a raspberry mead right now and I used the 1122 based on some info from Jimbo:
"Id order up some 71B1122 and some fermax. It will be worth the extra couple days wait. 1118 has a high alcohol tolerance, much higher than 71B1122. The point of this approach making a sweet mead is for the yeast to give up before the alcohol gets too high, leaving lots of nice residual sweetness. As it was I think I got to 15% ish range. With 1118 you'll hit 18% or 20%, it will be less sweet (obviously) and sharper to drink (40 proof). Also 71B1122 is known to accentuate fruity flavors in fruit ferments. It has some nice fruity esters of its own. 1118 is clean fermenting. You want this mead sweet, smooth and fruity, not crisp, dry and high alcohol. Thats basically all in the yeast."
The yeast has been working well. I'm step feeding my honey into the mead and I have about 5# left to add, then the fruit. All seems to be working great so far.
Re: 71B-1122
I use it when I ferment in the winter because it works at lower temps. I always liked what I've gotten out of it.
- cranky
Re: 71B-1122
I started with the 1122 last year because Jimbo recommended it. I like it and D-47 because they ferments cold and adds fruitiness but cuts can be a little difficult.
