Char Check
Char Check
Howdy. I've read about and done a little charing, and know that the "correct char" is subjective and the correct process is also subjective. I simply want to share some pics and get any feedback on my process of level of charring. The few specific questions are below..
For these toasts, I am using a propane torch adjusted down to a 1" long, 2.5cm, blue flame.
My sticks are 3/4" x 3/4" x 6" (2cm x 2cm x 15 cm)
To toast, I run the toarch down one side with a small zig-zag pattern, and the torch was touching each side of the stick for 10 seconds. I finish with a little char to the ends.
The result is a thin char, and I can see small hints of un-charred wood through the char. I am wondering if this char is enough for a Bourbon? This last pic includes a stick on the right with a bit more char on it. About 16 seconds per side. I can no longer see any un- charred wood through the surface. So in your opinion, is the thin char enough for jar aging, or perhaps the second deeper char? Maybe you think I should go even deeper? Just looking for opinions from those who have done much more of this than me.
Thanks. Otis
Thanks. Otis
- der wo
Re: Char Check
Both chars look all right.
The shorter the oaking time is, the better will taste the light char. More and finer taste from the oak, although perhaps the color of the Whiskey is lighter. The dark char will taste more unclear musty and will have the astringent dryness of wine. After a year both will be similar. Perhaps later the darker char will win. I am not sure.
Re: Char Check
I just accidentally did a light char on my oak and put it in malt whisky(ish) I find it has pulled through rather more vanilla taste than I was expecting. It has a mild taste and has put the correct character into the product in a short time. I shall continue with light toasts for the next few runs
Re: Char Check
I tend to replicate a #3 char on my charred white oak sticks. I believe a #3 char is what most Bourbon distilleries use. IMHO, a #3 is closer to a "alligator" char than any pictured. I have good luck with this level char, but have learned it is best to wash well after charring and the wood used is important as well. I get mine from a fire wood guy and only well seasoned white oak and I remove all sap wood before I char. I have also been playing around using a combination of well toasted sticks and #3'ish char sticks. I also just split my sticks to size and suspect that rough and un-even surface gives better results than the neatly sawn (I even seen guys plane them) pieces.
Good luck
BG
Good luck
BG
Re: Char Check
So was the accidental char from toasting a little longer/hotter than you planned? I'm leaning toward a Med Toast, light char myself for my next sugar head. One of my concerns is that I get enough char to be considered a light char, but not so light it is really just darkened wood. I thought my lighter of the two examples may be too light, but early feedback is that it's in the ballpark.Pikey wrote:I just accidentally did a light char on my oak and put it in malt whisky(ish) I find it has pulled through rather more vanilla taste than I was expecting. It has a mild taste and has put the correct character into the product in a short time. I shall continue with light toasts for the next few runs
Re: Char Check
Thanks for the feedback. I'll have to look up what a #3 is.boda getta wrote:I tend to replicate a #3 char on my charred white oak sticks. I believe a #3 char is what most Bourbon distilleries use. IMHO, a #3 is closer to a "alligator" char than any pictured. I have good luck with this level char, but have learned it is best to wash well after charring and the wood used is important as well. I get mine from a fire wood guy and only well seasoned white oak and I remove all sap wood before I char. I have also been playing around using a combination of well toasted sticks and #3'ish char sticks. I also just split my sticks to size and suspect that rough and un-even surface gives better results than the neatly sawn (I even seen guys plane them) pieces.
Good luck
BG
Unfortunately, I only have kiln dried wood at this time. Have read that natural dried heartwood, aged outside (covered) for two years is the good stuff. I will be looking for some of this good stuff in the near future.
RE: Splitting wood.
I know the increased surface area will give it's color and some flavor quicker. I see people selling toast and char sticks for major $$ with laser cut holes and 100s of micro groves, claiming to age product in days. I have to believe that not all aspects of aging can be speed up through more surface contact, or we would all simply be tossing a liberal pinch of toast/char dust into our bottles and calling it good. (Hey! has anyone tried this? I'm not serious.
Re: Char Check
i char for a simulation of #4 char. i have barrels charred to #4 and they have 1" square chunks about 1/16 thick of char that have fallen off and roll around in the barrel. i leave them in.
Talked to Jay Gibbs from Gibbs bros. cooperage today. he said (on top of being one of, if not the, oldest continuously run cooperages in the USA) all of their barrels are #4 char and was quick to point out that of the distilleries he services they have won many, many awards with his barrels.
now i drink for evil.
Re: Char Check
OtisT wrote:boda getta wrote:... I have to believe that not all aspects of aging can be speed up through more surface contact, or we would all simply be tossing a liberal pinch of toast/char dust into our bottles and calling it good. (Hey! has anyone tried this? I'm not serious.
Check the wine industry. Barrels, paddles, blocks, chips, and dust get used. All about surface area and level of toast.
I've been experimenting with oak charring and to get the color takes more char and to up the vanilla-sweet notes takes less char. Or so it seems so far.
From fish tank charcoal filters, the 'activated' charcoal works as a filter because the charing process results in huge surface area inside the wood that filter the fish water. Which seems like it matches in a way the pictures of the Jack Daniels charcoal bed filtering system I've seen. I've wondered how fast they get benefits from that process over the barrel aging systems?
- Oldvine Zin
Re: Char Check
For most of us in the wine industry it's about toast not char in our barrels. I recently tasted a wine that spent some time in a used charred bourbon barrel, guess what it tasted like? .... A used and spent barrel - not so pleasantCu29er wrote:
OVZ
Re: Char Check
I usually toast about 2 hours at 380. These sticks had been stored in airtight for a few months after that and were charred with propane torch immediately prior to use. The sticks had just about turned black and just caught fire. The fire was put out with water and they were used straight away.OtisT wrote:So was the accidental char from toasting a little longer/hotter than you planned? I'm leaning toward a Med Toast, light char myself for my next sugar head. One of my concerns is that I get enough char to be considered a light char, but not so light it is really just darkened wood. I thought my lighter of the two examples may be too light, but early feedback is that it's in the ballpark.Pikey wrote:I just accidentally did a light char on my oak and put it in malt whisky(ish) I find it has pulled through rather more vanilla taste than I was expecting. It has a mild taste and has put the correct character into the product in a short time. I shall continue with light toasts for the next few runs
- Swedish Pride
Re: Char Check
i think heavy char for bourbon and lighter char for Irish and scotch is just about right.
or even better use heavy char for a bourbon, then take it out and use it for Irish ( not that I've ever heeded my own advice)
Don't be a dick
- Single Malt Yinzer
Re: Char Check
Sorry for the big pic, but it is needed to see the char levels. Legal Bourbon must use Char 3(Edit: This is wrong, see below). Looks like you're closer to 1 or 2. Article below has good info near the bottom on charring.
http://www.distillerytrail.com/blog/und ... s-not-age/" onclick="window.open(this.href);return false;" rel="nofollow
Last edited by Single Malt Yinzer on Tue Aug 22, 2017 10:20 am, edited 1 time in total.
Re: Char Check
How long are you going to age the spirits?OtisT wrote:So in your opinion, is the thin char enough for jar aging, or perhaps the second deeper char? Maybe you think I should go even deeper?
Re: Char Check
I guess the two likely answers are as long as it takes and as long as I can stand letting them sit before I can't wait any longer and crack them open.shadylane wrote:How long are you going to age the spirits?OtisT wrote:So in your opinion, is the thin char enough for jar aging, or perhaps the second deeper char? Maybe you think I should go even deeper?
Seriously, I would like somewhere between 6 to 9 months for pint jars, but I'm patient and don't mind going a year or longer when necessary.
Reading comments here and on other threads, I'm thinking the heavier the char, the longer the aging before the char smell/flavor is tamed by the spirits.
- ShineonCrazyDiamond
Re: Char Check
According to who?Single Malt Yinzer wrote:
Legal Bourbon must use Char 3.
Shine on you crazy diamond."
Re: Char Check
The Federal Standards of Identity for Distilled Spirits (27 C.F.R. 5) state that bourbon made for U.S. consumption must be:
- Produced in the United States
Made from a grain mixture that is at least 51% corn
Aged in new, charred oak containers
Distilled to no more than 160 (U.S.) proof (80% alcohol by volume)
Entered into the barrel for aging at no more than 125 proof (62.5% alcohol by volume)
Bottled (like other whiskeys) at 80 proof or more (40% alcohol by volume)
Bourbon has no minimum specified duration for its aging period. Products aged for as little as three months are sold as bourbon. The exception is straight bourbon, which has a minimum aging requirement of two years. In addition, any bourbon aged less than four years must include an age statement on its label.
Re: Char Check
That's true, also time is needed for the char to color the whiskeyOtisT wrote:shadylane wrote:OtisT wrote:I'm thinking the heavier the char, the longer the aging before the char smell/flavor is tamed by the spirits.
Correct me if I'm wrong
You want to age whiskey for 6 -9 months in pint jars
Edited thanks for the post, those chared sticks look like a pro did them
Re: Char Check
Yup - I was wrong, any char will do. Not sure what I thought it had to be #3.ShineonCrazyDiamond wrote:According to who?Single Malt Yinzer wrote:
Re: Char Check
Is that an issue? The 6-9 months would be nice, but I will let them sit as long as needed. My original plan for needing charred sticks is on hold. I was recently gifted my first barrels, three new American oak Med Toast/Heavy Char barrels (one 5l and two 2l, Best Brother in the World) so first I will be filling at least the big one before I have a chance to try out any new sticks. I'm doing my last HBB ferment now that will give me enough to fill it. So close.shadylane wrote: Correct me if I'm wrong
I am also planning to play with various toasts and chars with other bases, like some sugar heads and rums. I make a molasses head rum using spent HBB grains that I think may be good with a light toast/char. Time will tell.
Re: Char Check
Not really an issue, it will be a little different than say gallon jugs.OtisT wrote:Is that an issue? The 6-9 months would be nice, but I will let them sit as long as needed.shadylane wrote: Correct me if I'm wrong
A problem I've had ageing in small containers is it's real easy to get carried away with the char
Re: Char Check
A bigger problem in my experience is that it's easy to get carried away in the "testing" and end up with empty jarsshadylane wrote:
............A problem I've had ageing in small containers is it's real easy to get carried away with the char
Re: Char Check
thats so funny
thats so funny
Re: Char Check
tonight is a white(gin) night ....trying to keep out of my aging stock cant wait till spring already to get back at all grain so very much is learned here...i can still smell the sweet smells of the oak i charred today
Re: Char Check
one day after adding char oak i see color just barely coming on but the smell already sweet vanilla smoky im liking my other two uj gallons are store bought in color already after two days 1 french med toast 1 med toast amer oak... ill have to do this on the all bran recipe too
Re: Char Check
My OP showed a pretty light charring. Figured I would add something more in line with what I have been using more recently. 25 seconds under the propane flame thrower.
This is some chunks of toasted Apple I did a few months back for some rum and other future spirits. I put these on a wire screen to get the flames to wrap around the sides. After charring one side I doused them in water then flipped them over for a char on the back side.
After soaking The toasted/charred apple in rum for 4 months, I pulled the chunks and split them to be put in proofed down bottles of rum. This is a nice view showing the depth of this char. Otis
Re: Char Check
so just a little update my 3 uj gallons are colored up nice the charoak looks like a honey color
