I been buying toasted and charred sticks from an eBay seller for few years now but trying to order a few days ago seems he's disappeared. There's no oak growing in this province, and every hardware store and cabinet maker I ask say everything they have is kiln dried. I age in 1 gallon jugs.
Can anyone point me in the right direction for a supplier or have an abundance of oak lying around (to sell, not looking for handout)? I can toast and char myself!
Oak Supplier
Oak Supplier
Swedish Pride wrote:
Re: Oak Supplier
Broken barrel staves from a winery?
Have to clean and toast and char, yourself, but they are probably free....
- Badmotivator
Oak Supplier
Kiln dried is not a problem. Killing [EDIT: oops. Kilning!] won’t add anything bad to the wood. You should buy some right now, cut it into pieces slightly larger than you like to use, stack it outside in the rain, and forget about it through the winter. Or even better, through a couple of winters. Before you know it you’ll have an ample supply of wonderfully seasoned/weathered oak. Plane off the outer layers, toast and char as you like it.
Just like aging your spirits, you gotta age your oak before use. Get started now and you won’t regret it later.
Trying to make it real compared to what?
Badmotivator Barrel Construction, Start to Finish
Re: Oak Supplier
I'm picking some up this week to do just that, ill have plenty for the ffuture, but ive got one batch waiting oak now, and another 2 ready to run. I guess I assumed my oak guy would always be there but he seems to be gone into hiding.Badmotivator wrote:Kiln dried is not a problem. Killing won’t add anything bad to the wood. You should buy some right now, cut it into pieces slightly larger than you like to use, stack it outside in the rain, and forget about it through the winter. Or even better, through a couple of winters. Before you know it you’ll have an ample supply of wonderfully seasoned/weathered oak. Plane off the outer layers, toast and char as you like it.
I called the only winery within a days drive, they only age in stainless tanks, no wood.The Baker wrote:Broken barrel staves from a winery?
Re: Oak Supplier
Badmo. I have a lot of old quartersawn oak that has sat dry, in my basement, for 15 years. It’s a couch/chair project I abandoned years ago. Would this need to weather outside too to be considered good quality aging oak?Badmotivator wrote:Kiln dried is not a problem. Killing [EDIT: oops. Kilning!] won’t add anything bad to the wood. You should buy some right now, cut it into pieces slightly larger than you like to use, stack it outside in the rain, and forget about it through the winter. Or even better, through a couple of winters. Before you know it you’ll have an ample supply of wonderfully seasoned/weathered oak. Plane off the outer layers, toast and char as you like it.
I’m thinking of taking the thicker material and making a few of your BadMo Barrels with it, as you suggested previously.
- Badmotivator
Re: Oak Supplier
I believe it still needs to feel real weather. Hot, cold, wet, dry, wind, fungi and bacteria etc. The tannins haven't gone anywhere in all that time it was sitting in the basement, and there's been no microbial activity to speak of. If you use it now you will give your spirit a harsh, tannic, green-stick flavor.OtisT wrote:
Hope that helps.
