Barrel Surface Area to Volume (SA/V) Measurements
This post does not appear to be displaying properly in Tapatalk. Please switch to browser view.
I have had a miserable time trying to get reliable measurements for surface area to volume ratios in large barrels. I’m going to name some of the problems and discuss solutions to them. I include some measurements here and hope to help others avoid some of the frustrations I have had trying to pin down the numbers.
- Problems with finding SA/V measurements:
- Very few people are interested in precise measurements of interior SA/V, so very little is written about it. Much of the writing you do find is about generalities (i.e. “Small barrels have a higher SA/V so your spirit will age faster ha ha”) and are not helpful.
- There are a few websites with charts showing interior surface area of a range of barrel sizes, for example from Deep South Barrels, Red Head Barrels, Tall Ship Barrels, et. al, but upon inspection their numbers are insane. To give you some idea of how insane they are… to match their claim that the SA for a 53 gallon barrel is 6535 in2, a cylinder would have to have a 3.8” radius and be 22.5 feet long. This is a real issue, because these numbers are readily available, easily found by a Google search, and dangerously incorrect. If you were to follow their numbers, you may damage your spirits. Let's say this again, but in bold: Deep South Barrels and Red Head Barrels surface area to volume charts are wrong. Don't use their numbers for anything.
- Barrels come in many different volumes and geometries. Bourbon barrels are reasonably standardized, but many spirits are aged in hogsheads, butts, barriques, etc. If you are looking to match the characteristics of the spirit you like, it will be tough to get measurements of the surface area to volume ratio that is appropriate for you to aim for.
- The real-world geometry of a cask is a challenge to work with. Nobody wants to integrate that curve. In truth, you can make some fairly simple approximations of the proportions of a cask, and the results you get from your calculations with that approximation will be pretty good. But we will have to keep in mind that the accuracy of our numbers is not especially high. Common methods for approximation are a 1) a simple cylinder, or 2) two truncated cones or conical frustums.
- On the rare occasion that you do find a measurement for a particular barrel, the units are all over the place, which means that comparing apples to apples requires a spreadsheet. I have seen in2/gal, cm2/gal, cm2/L, and even gal/ft2!
- The effective SA/V ratio in a barrel changes fast as the level of the liquid gets lower in the barrel. For example, by my calculations, by the time a bourbon barrel has lost 10% of its volume (often in the first year!), the contact SA/V ratio is 88% of that of a full barrel. I'm not sure what folks will do with this information except keep it in mind when they are aiming for a reasonable amount of wood in their spirits.
Okay. So what can we do to get good numbers? We can get a whole bunch of reasonably reliable numbers from industry, academia, hobbyists' approximations, etc., convert them to similar units, and see if the numbers tell a coherent story. Let's do that next. Red columns are gallons and inches, blue are liters and cm.
[tr][th]Name of Source[/th][th][color=#FF4000]Barrel Volume (gal)[/color][/th][th][color=#8040FF]Barrel Volume (L)[/color][/th][th][color=#FF4000]Interior Surface Area (in[super]2[/super])[/color][/th][th][color=#8040FF]Interior Surface Area (cm[super]2[/super])[/color][/th][th][color=#FF4000]SA/V (in[super]2[/super]/gal)[/color][/th][th][color=#8040FF]SA/V (cm[super]2[/super]/L)[/color][/th][th]Source URL[/th][/tr]
[tr][td]Read Head Oak Barrels et. al[/td][td][color=#FF4000]52.8[/color][/td][td][color=#8040FF]200[/color][/td][td][color=#FF4000]6535[/color][/td][td][color=#8040FF]42161[/color][/td][td][bg=#FF8040][color=#BFFF40]124[/color][/bg][/td][td][bg=#FF8040][color=#BFFF40]211[/color][/bg][/td][td]https://redheadoakbarrels.com/barrel-info/barrel-dimensions/ https://www.deepsouthbarrels.com/page/barrel-dimensions/barrel-dimensions" onclick="window.open(this.href);return false;" rel="nofollow https://www.tallshipbarrels.com/blogs/barrel-dimensions/barrel-dimensions" onclick="window.open(this.href);return false;" rel="nofollow[/td][/tr]
[tr][td]Schahinger and Rankine (1992)[/td] [td][/td] [td][/td] [td][/td] [td][/td] [td][color=#FF4000]53[/color][/td] [td][color=#8040FF]90[/color][/td] [td]https://www.extension.iastate.edu/wine/oak-aging-red-wine[/td][/tr]
[tr][td]Brouweij Chugach (wine, nominal)[/td] [td][color=#FF4000]65[/color][/td] [td][color=#8040FF]246[/color][/td] [td][color=#FF4000]3401[/color][/td] [td][color=#8040FF]21942[/color][/td] [td][color=#FF4000]52[/color][/td] [td][color=#8040FF]89[/color][/td] [td]http://brouwerij-chugach.com/?page_id=940[/td][/tr]
[tr][td]Pisoni Vineyards[/td] [td][color=#FF4000]60[/color][/td] [td][color=#8040FF]227[/color][/td] [td][color=#FF4000]3060[/color][/td] [td][color=#8040FF]19742[/color][/td] [td][color=#FF4000]51[/color][/td] [td][color=#8040FF]87[/color][/td] [td]https://pisoninotes.com/notes/barrel-sizes-matters-lucia-chardonnay/[/td][/tr]
[tr][td]Wines and Vines Magazine article[/td] [td][color=#FF4000]59.4[/color][/td] [td][color=#8040FF]225[/color][/td] [td][color=#FF4000]3255[/color][/td] [td][color=#8040FF]21000[/color][/td] [td][color=#FF4000]55[/color][/td] [td][color=#8040FF]93[/color][/td] [td]https://www.winesandvines.com/features/article/166780/Barrel-Rescue[/td][/tr]
[tr][td]Poppyseed Cellars[/td] [td][color=#FF4000]59[/color][/td] [td][color=#8040FF]223[/color][/td] [td][color=#FF4000]3178[/color][/td] [td][color=#8040FF]20503[/color][/td] [td][color=#FF4000]54[/color][/td] [td][color=#8040FF]92[/color][/td] [td]http://nielsj.users.sonic.net/3099/?p=48[/td][/tr]
[tr][td]barrels and aging lecture slides[/td] [td][color=#FF4000]53[/color][/td] [td][color=#8040FF]201[/color][/td] [td][color=#FF4000]2824[/color][/td] [td][color=#8040FF]18219[/color][/td] [td][color=#FF4000]53[/color][/td] [td][color=#8040FF]91[/color][/td] [td]http://srjcstaff.santarosa.edu/~jhenderson/Barrels.pdf[/td][/tr]
[tr][td]Brouwerij Chugach (whiskey, nominal)[/td] [td][color=#FF4000]53[/color][/td] [td][color=#8040FF]201[/color][/td] [td][color=#FF4000]2997[/color][/td] [td][color=#8040FF]19335[/color][/td] [td][color=#FF4000]57[/color][/td] [td][color=#8040FF]96[/color][/td] [td]http://brouwerij-chugach.com/?page_id=940[/td][/tr]
[tr][td]OtisT’s calculation[/td] [td][color=#FF4000]49.5[/color][/td] [td][color=#8040FF]187[/color][/td] [td][color=#FF4000]2870[/color][/td] [td][color=#8040FF]18516[/color][/td] [td][color=#FF4000]58[/color][/td] [td][color=#8040FF]99[/color][/td] [td]via email, based on JD barrel measurements and reasonable assumptions[/td][/tr]
[tr][td]Cylindrical 11”R 53gal “barrel”[/td] [td][color=#FF4000]53[/color][/td] [td][color=#8040FF]201[/color][/td] [td][color=#FF4000]2986[/color][/td] [td][color=#8040FF]19264[/color][/td] [td][color=#FF4000]56[/color][/td] [td][color=#8040FF]96[/color][/td] [td]my calculation. Radius- and volume-constrained cylinder[/td][/tr]
[tr][td]Cylindrical 12”R 53gal “barrel”[/td] [td][color=#FF4000]53[/color][/td] [td][color=#8040FF]201[/color][/td] [td][color=#FF4000]2944[/color][/td] [td][color=#8040FF]18994[/color][/td] [td][color=#FF4000]56[/color][/td] [td][color=#8040FF]95[/color][/td] [td]my calculation. Radius- and volume-constrained cylinder[/td][/tr]
[tr][td]Calculation using two truncated cones[/td] [td][color=#FF4000]53.2[/color][/td] [td][color=#8040FF]201[/color][/td] [td][color=#FF4000]3051[/color][/td] [td][color=#8040FF]19686[/color][/td] [td][color=#FF4000]57[/color][/td] [td][color=#8040FF]98[/color][/td] [td]my calculation - brute forcing volume with reasonable radii and length[/td][/tr]
I think the story is pretty clear. First, the "relative aging time" chart floating around on the websites of small barrel merchants is a load of bull. Second, the SA/V of 53 gal/200L American Standard Barrels is in the neighborhood of
56 in2/gal or
96 cm2/L. Those numbers are only about 5% lower for the larger barrels. If you are looking for measurements on slightly bigger or slightly smaller barrels than those in the chart you can probably interpolate the numbers safely.
I hope this post helps and can be a point of reference for future discussions about aging using oak. Cheers.
