Rum run question?
midlife-u-turn
Rum run question?
Post by midlife-u-turn »
I ran my first rum wash the other day. I have a combo/reflux column still and my intention was to do a stripping run and pump it through fast and carry over as much flavor as I could. I used Grandma's food grade original molasses and brown sugar. I had 3 wound copper mesh wraps in the column (which I've used in the past) but did not run any reflux. It started at 85% ABV and I took it down to 20%. The rum is good and clean tasting but not as much flavor as I expected. My question is- 170 proof is much higher than I expected with just passive reflux and running it fast. I have two batches currently in the fermenters and am wondering if I should continue to strip each similarly or should I just run it once with a little reflux and put it on some oak. My concern is if I strip it at that ABV and run a spirit run am I just going to be losing out on more flavor. 1 1/2 run? Thoughts?
bearriver
Re: Rum run question?
Post by bearriver »
If you mix your entire stripping run collections, it comes out at 170 proof?
Can we see the still?
midlife-u-turn
I thought I should have clarified that a little better. Since it was a stripping run I didn't collect in pint jars as usual. I guess if it was linear it would average about 55%. Not overly high I guess for a stripping run but I collected down to 20%. I know it's a newbie question but I guess I'm looking for a little validation. Continue as is or do a single run, run a little reflux up the ABV, put it on oak and call it good?
I could be questioning myself because I ran an all grain barley the other day with the intention of running it twice. Same set up etc. it came out at around 55% and I decided just to put it on oak as is. I'm a M.A.S.H. junkie and to quote Col Potter there are not enough OOOs in Smooth to describe it already. Am I going to benefit, other than volume reduction, by running it twice?
Drunk-N-Smurf
Post by Drunk-N-Smurf »
If you want flavour, then a pot still is best. I don't know if you can run yours as a pot still? But that would be the way to go.
I haven't seen your still, but it's always better to run twice IMHO. Removes a lot of impurities left over from the strip run.
With my pot still, even after triple distilling, I still have loads of flavour.
Hangover? I don't get no stinking hangover!
Tokoroa_Shiner
Post by Tokoroa_Shiner »
Can you take the packing out? That would make it more like a pot still
The Rules By Which We Live By
Safety And Related Issues
New Distillers Reading Lounge
midlife-u-turn
Thanks guys,
I'll remove the copper mesh rolls for the next runs and run it twice.
I could also significantly reduce the height of the column although it's kind of nice having that little distance if I get a some foaming.
I have found that cooking spray with the anti foaming agents works great for addressing that.
Thanks again
