Feed Grade Molasses
Shifty
Feed Grade Molasses
Hi there,
Was in a feed store a few towns away, and they are selling jugs of "Feed Grade" Molasses that contains = Molasses and Propionic Acid (preservative). It says "Not for human consumption", but is that simply because there is no FDA testing for feed grade foods? Anyone used a similar product for a rum wash?
Thanks!
Shifty
Thanks!
Shifty
Grayson_Stewart
Most unsulfured molasses will say "Not for human consumption". The sulfured molasses is treated to keep down infections in the molasses. I don't think you are going to "consume" the molasses on your breakfast biscuits are you? You're gonna put it in a mash, ferment it out and then distill it I assume. Should be fine.
Virginia Gentleman
What Grayson said.
Grayson, does a preservative like Propionic Acid ever slow sugar conversion down, or is there not enough in there to have any effect?
Man, I gotta find a feed store that carries it. The 2 in town don't, so I'll have to branch out.
Lord preserve and protect us, we've been drinkin' whiskey 'fore breakfast.
Grayson_Stewart
I can't answer that question because I don't know the amount of the acid used. I do know that I've successfully fermented many juices that had preservatives.
If you are going to make a rum from molasses, usually you will use a gallon of molasses with 10 gallons of water plus the added sugar. Tater taught me this ratio. Anything more seems to have an over powering taste. Using this ratio should further lower the concentration of the acid in the wash.
When fermenting anything that you think may have a preservative added, be sure to pitch a large starter. Thats a "REAL" starter...not just some rehydrated yeast. Make sure you get a good colony multiplied and starved for food then pitch it in the wash.
Here is a link to more info on Propionic Acid. You can see on the information on the link that the acid has a boiling point of 141 C so I wouldn't think there would be any concern of it coming across in the distilate.
Yttrium
Virginia Gentleman
Yttrium
- Tater
i use feed grade molasses cost 10 cents a lb and a gallon weighs 12lb. i use 2 gallons molasses with 20lb sugar that was boiled in water and poured hot in the molasses . to give a total of a 13 gallon wash If ya remember gray it was 10 lb sugar to a gallon molasses.
Guest
Virginia Gentleman
- Tater
the feed grade molasses i use i figure =to 5 lbs sugar per gallon with 2 gallons of it and 20 lbs sugar in a 13 gallon wash i usally get 3 gallons of 100 to 110 proof. i quit collecting at 8o proof and do a single run using distillers yeast prestarted in some of the wash i also add 1/4 cup lime juice to wash.; [grand pa allways told me that 10 lb sugar however you get it should bring a gallon of 100 proof likker]hope this helps
Virginia Gentleman
AkCoyote
Yttrium
Rocky_Creek
AkCoyote
The dry molasses is full of urea. Very questionable.
