FYI.All Coconut Sugar is not made with the sap of the palm!
Tresomega Nutrition Organic Coconut Sugar.
Ingredients: Contains Tree Nuts (coconut)
Packaged in a peanut-free facility.
HOWEVER when you desolve it in water I would recommend that you filter it...or not.
Re: FYI.All Coconut Sugar is not made with the sap of the pa
What the hell is going on here. I'm cornfused.
I found some coconut sugar that's actually made from the nut!
Fermentation is fantastic tastes fabulous, sweet and smooth slightyt nutty.
When desolved there is partials of the shell, needs filtering out. Before distillation.
Every post I've seen says that Coconut Sugar is made from Palm tree sap.
I gave y'all the name of it.tryit you'll be amazed at the results.
What part of All Coconut Sugar is not made with the sap of the palm. is cornfusing you?pfshine wrote:What the hell is going on here. I'm cornfused.
- MichiganCornhusker
Well...olelucky46 wrote:What part of All Coconut Sugar is not made with the sap of the palm. is cornfusing you?pfshine wrote:What the hell is going on here. I'm cornfused.
"All Coconut Sugar is not made from the sap of the palm" sort of means that No Coconut Sugar is made from the sap of the palm.
But, I believe Some, perhaps Most Coconut Sugar is made from the sap of the palm.
On the other hand, Some, but Not All Coconut Sugar is not made from the sap of the palm.
Some's made from a coconut.
But in a peanut-free facility.
Hmm your first post is all jacked up and all don't make sense. Then you go and you recommend filtering OR not which doesn't make literary sense.olelucky46 wrote:What part of All Coconut Sugar is not made with the sap of the palm. is cornfusing you?pfshine wrote:What the hell is going on here. I'm cornfused.
Edit to add perhaps it's just the way you talk/write that doesn't make sense. It can be a chore to get what you want to say come across.
- Hillbilly Popstar
So maybe this would be a good think to add to a rum ferment?
Sent from my SAMSUNG-SM-G870A using Tapatalk
You can.....But I suggest making a run just with the Coconut Sugar first, then decide whether you want to mix it up.Hillbilly Popstar wrote:So maybe this would be a good think to add to a rum ferment?
The taste is unique! Completely different than any other sugar.
this sugar has particals of finely ground nut, which settles to the bottom when desolved in water. So I would recommend filtering as you add it to your fermenter.
I apologize. I can see where it could be confusing.All I wanted to do is make it known that there is a Coconut Sugar made out of the actual Coconut not the Palm. When desolved in water there are particals of the nut that should be filtered out be for adding it to your fermentation vessel. And that the product produced has a fantastic flavor.pfshine wrote:Hmm your first post is all jacked up and all don't make sense. Then you go and you recommend filtering OR not which doesn't make literary sense.olelucky46 wrote:What part of All Coconut Sugar is not made with the sap of the palm. is cornfusing you?pfshine wrote:What the hell is going on here. I'm cornfused.
Just try it... and let me know what you think.
- Hillbilly Popstar
Why should you filter them before fermenting. All kinds of crazy crap goes into the fermenter.
I found out that there was a lot of the shell settled out when you desolved the sugar and it stuck to the bottom of the Turbo 500 and took a lot cleaning.Hillbilly Popstar wrote:Why should you filter them before fermenting. All kinds of crazy crap goes into the fermenter.
- Hillbilly Popstar
Ah...
Well I don't know how that turbo 500 works, but normally that sediment would just stay in the fermenter with the trub when you siphon the wash off into the boiler.
You're right the first batch brought some of the shell over when I transferred it to the boiler, evidently I didn't wait long enough for it to completely settle out. There isn't much solids that settle out except the yeast and a little bit of shell.
Second run went smoothly.
- DetroitDIY
So I'm preparing to ferment a batch of straight Panela, but I'm a bit short and happen to have a bag of "blond organic coconut sugar" from Big Tree Farms. Ingredient is "granulated coconut flow blossom nectar". I gather this means that is the palm sap and not the tree nut.
I see Olelucky is advocating to not mix the sugars. Any other experience out there on this? I don't want to mess up my panela but do want to max out my fermenter volume. The ratio of sugars would be about 90% Panela, 10% Coconut sugar.
I've also been curious about fermenting a straight batch of this coconut sugar, but don't have a ton on hand.
