Feed grade molly and brown sugar wash
I started today a wash that consists of the following
2 gallons feed grade molly
18 lbs dark brown sugar
1/2 cup rehydrated bakers yeast
Total volume is around 15 gallons
The hydrometer read 1.100 and from what I know that will be off a bit due to the unfermentables in the molly.
I loaded the molly and brown sugar in the fermenter then heated 6-7 gallon of h20. Once very hot not boiling I dumped into the fermenter and mixed thoroughly. Then I brought the water hose in and filled the rest with the jet setting. I feel that did the proper job with aerating, I then put some wash into a pot and slowly added the yeast stirring with a whisk untill no clumps were evident. It's still rehydrating as I type. I will add once it doubles in size
I'm hoping it will finish by next weekend so that I can use my time off to still.
Any comments are welcome good or bad
Re: Feed grade molly and brown sugar wash
OK, here comes...Shine0n wrote:...Any comments are welcome good or bad
You should rehydrate dry yeast with warm water only...not wash. The sugar in the wash can cause the yeast cells to rupture when the osmotic pressure squeezes the cell membrane. Until they're filled with water and the cell walls are once again moist, they are very fragile.Shine0n wrote:...I then put some wash into a pot and slowly added the yeast stirring with a whisk untill no clumps were evident. It's still rehydrating as I type...
Well, that's a lot of sugar. A gallon of molasses is roughly 12 lb. So, 2 gallons is 24-25 lb. plus 18 lb. dark sugar = 42-43 lb. in a 15 gallon ferment. That's approximately 2.8 lb./gallon...plenty of potential alcohol there.Shine0n wrote:...2 gallons feed grade molly...18 lbs dark brown sugar...around 15 gallons...hydrometer read 1.100..
Did you make a "yeast bomb"? I always do with raw (feed grade) molasses.
No I didn't do a yeast bomb, I don't have the things necessary for that. The molly said it 43% sugar so I hope I didn't over do it. The last one I did 4 gallons fancy and 8 lbs brown sugar and it went fine. I hope this is the case for this one
SS, do you mean total weight in a gallon or lbs of sugars?
If it were 12 total the sugars at 43% would do not be that much sugar that would mean less than or right at 10 lbs total sugar right?for 2 gal.
I put the aquarium aerator in for the night and will stop in the am.
The amount of yeast i put in the starter, whatever died would be consumed by the survivors right? Since they are cannibalistic. They tripled in size before I added them to the fermenter, I forgot to mention that it wasn't all wash it was half and half with h20. Sorry
I looked up molly to see what kind of special feed grade molasses you were using.
I came up with several girls who use that name, and an illegal drug.
- Oldvine Zin
LOLcob wrote:I looked up molly to see what kind of special feed grade molasses you were using.
OVZ
- Oldvine Zin
So at the winery that I work at we always rehydrate the yeast with the grape juice that they will be living in - seems to be a happy relationship, Ive been doing the same with all of my ferment's with no issues, Maybe we are killing off too many cells ???still_stirrin wrote:You should rehydrate dry yeast with warm water only...not wash. The sugar in the wash can cause the yeast cells to rupture when the osmotic pressure squeezes the cell membrane. Until they're filled with water and the cell walls are once again moist, they are very fragile.
OVZ
The little fellas are doing their thing this am and looks good.
OVZ, I've been doing it the same way for quite some time myself and haven't encountered any problems as of yet.
Cob- funny stuff, I looked up molly this am and seen the same. I said molly one day at work referring to molasses and one guy said "I love molly" I don't think he was talking about molasses though. Lol
OK, it has been working for you that way.....until it doesn't.Oldvine Zin wrote:So at the winery that I work at we always rehydrate the yeast with the grape juice that they will be living in - seems to be a happy relationship, Ive been doing the same with all of my ferment's with no issues, Maybe we are killing off too many cells ???still_stirrin wrote:You should rehydrate dry yeast with warm water only...not wash. The sugar in the wash can cause the yeast cells to rupture when the osmotic pressure squeezes the cell membrane. Until they're filled with water and the cell walls are once again moist, they are very fragile.
If the yeast is fresh, like the winery probably bought directly from the distributor in larger (fresher) volumes, then the yeast may be hearty enough to survive the damaging start. What instruction did the producer give to you to rehydrate their products? Did they give you a recipe which had sugars in it, and I'm talking about "rehydration", not "making a starter".
I know that the bakers yeast that I buy at the grocery has instructions to rehydrate 15 minutes is warm water (body temperature, ie-98*F). And brew sites will advise the same when using dry yeast.
If your method is working for the amount of yeast you're using, then great. All I'm suggesting is that if you pay attention to how you rehydrate the yeast, it may work BETTER.
One thing to note about yeast in fermentation is that they'll reproduce (called, "budding") until the optimum cell concentration is achieved. Healthy yeast in a healthy environment (proper nutrient and oxygen levels) will reach that point quicker and generate healthier yeast which perfoms its function better (less mutations and reduced bad fermentation byproducts).
Why wouldn't you at least try to make the environment better, especially since it is really easier to do, ie - using warm water instead of wash to rehydrate?
ShineOn, sorry for the "derailment" from your original subject, but the discussion on yeast somewhat evolved.
There is one more thing that comes up from time to time pertaining to using dry yeast, and that is that some "sprinkle it on top and stir it vigorously". I'm somewhat mixed on the value vs damage to this process, as stirring vigorously can introduce some air (oxygen and more) into the wort/must, goodness, although there are better ways to aerate as well.
But a violent stirring, especially with dry, brittle yeast cells can fracture and pulverize the cell structure. But the cell walls contain nutrients which are valuable for yeast when budding. It provides energy for regeneration of cell growth. So, you lose some...and in turn, you gain some.
However, if the yeast was outdated, that is, it has been sitting around too long (the packages are dated, just look for it), then you may find that your processes simply won't work and the ferment will not start properly, if at all.
A test for yeast viability is when you rehydrate (in warm water), does the yeast smell "bready", or somewhat "yeasty". Or does it smell "powdery", like dirt/dust? If it smells good, like bread, then its probably very healthy. If it smells like dust, without the fresh smells, then it is probably old and may not be healthy enough to pitch. If this is the case, try making a low gravity starter solution (1/4 to 1/2 liter @ 1.010-1.020) and put the rehydrated yeast into it, shaking it good at the onset. Let it start for 24 hours before pitching into your ferment, enough time to let the starter generate new cells. If its dead, you'll know it (no CO2 production and a dirty, dusty smelling starter), so don't waste time wondering if your ferment will work.
Get fresh yeast as soon as possible to pitch.
I take all advice into consideration and have pretty thick skin.
For 99% of my washes I use bread yeast and use a pretty decent amount on each, I don't reuse the grains on the sf I just use new since so inexpensive so it's new yeast every time as well.
The rum this time is different than what I usually do, my normal rum would be 4 gal unsulphured fancy and 8 lbs dark brown sugar into around 18 gallon.
This was 2 gal feed grade and twice the brown sugar, if this doesn't turn out the way I want I'll just go back to my original rum. This one is slightly cheaper with feed grade and the sugar was on sale for 1.25 for 2 lbs so why not try right?
I didn't mention I run a 2" pot keg with a 7.5 gal thumper to a 40' 5/8" worm in a 40 gal cooling barrel. I plan on upgrading my thumper to full keg with a liebig this spring when the weather is nice. I've used this style setup for years and has done well! I still may use the 7.5 as a 2nd thumper for rums.
- Oldvine Zin
Well I'm here to learn so I'll try that next ferment..Thanks ssstill_stirrin wrote:
OVZ
I'm here to learn as well and may try that at some point,Oldvine Zin wrote:Well I'm here to learn so I'll try that next ferment..Thanks ssstill_stirrin wrote:
OVZ
But why stray away from a proven method of rehydrating? I've learned alot here from the old way I did things and have changed, I just don't see how water is a better method when your putting them into a sugary solution. When I use wash, they are being multiplied in the exact same wash that they will be introduced to and have already been adapted to that it so there is no shock factor.
- Oldvine Zin
That's our thoughts also but since this is my hobby I'm willing to experiment and try different methods, and maybe proved wrong?Shine0n wrote:
OVZ
OVZ, Very true!!! I'm not saying at all I won't try it because I didn't become a better than average stiller by not taking suggestions. Just wondering how it was better that's all, when I make bread I don't use alc. to prime my yeast lol
On topic though, the rum is running wild as of this morn, should be ready in a couple days and I'll start the New Year off with a good run!
- rgreen2002
Just another opinion but when I make a starter I use DME. So I am not really hydrating only. On the flip side I make a DME starter aroung 1.04 so it's not the 1.06-1.07 of the wash (OR higher with molly) so maybe a little stress is good but not too much...?
$0.02 cents given...
HD Glossary - Open this
I've always used half wash and half h20, it's pretty weak. It's never let me down but I'm willing to try anything once and if I don't like it I won't try again.
I'm only doing a single run with the pot/thumper so I'm hoping the flavor of the feed molasses is tamed a bit, the fancy had a great smell right from the start and the feed grade was quite harsh. If I'm not fond of it I will simply dilute it to 35% and use it in my Thumper for my next sf wash and have some rumsky. Win win
- Truckinbutch
I like the way you think .Shine0n wrote:I've always used half wash and half h20, it's pretty weak. It's never let me down but I'm willing to try anything once and if I don't like it I won't try again.
Well, my aquarium heater went ape shit and heated up my wash to 136°f
That's a bummer! I'll let it cool down and take a reading to see where abouts it is.
This is a first for me now not sure what to do. Damn it man I was looking forward to this.
Oh well
Oh well
- ShineonCrazyDiamond
No worries. Just cool it back down and pitch new yeast. The old will be food for the next ones. Your good!
Shine on you crazy diamond."
Shineon, that's exactly what I was hoping I could do. Once it cooled down some I tasted it and it was bitter, I'm not to sure it wasn't finished. I checked with hydrometer and said .020 but it was still pretty warm and Im lookin now for the conversion for temps.
From the calculators I've done and with the temperature difference as it sits now is 10.01%
I'm sure the readings are off a bit due to the molasses, it is pretty bitter and has no hint of sweetness.
I'm just going to run it and see how it turns out. It may just turn out fine, we'll see tomorrow
Yeah, i didn't know the rest of the particulars, but was going to let you know that If you used feed grade molasses, 1.02 is probably done. Run away . Wish I had something to run today. Guess I'll just go make a stout to fill my keg withShine0n wrote:From the calculators I've done and with the temperature difference as it sits now is 10.01%
*Edit to say I scrolled my lazy ass down to read your original post. That sucker is done! Have fun!
Might be a good idea to also check the pH before pitching new yeast...
I checked the gravity at the right temp last night and it's at 1.028, there is no hint of sweetness so Ima strip it some night this week and use what's left in the fermenter as nutes for the next rum wash with some dunder.
As this being my first with feed grade molly will I benefit from multiple strip and then a spirit run?
I love the bold flavor I got from the fancy, I'm not so sure this will be the same. I'm running with a thumper and will add the feints from my last sf to the thump and some water in hopes to help smooth/clean up the spirit.
In all the rum made with fancy molasses I did 1 slow (very slow) spirit run
Well the strip is complete and have now 2.5 gallons of low wines. I didn't have a large enough container to collect all at once so it's in 1 gal glass jugs, I'll combine it all together in a ss pot the measure abv so ill know if it need further cutting down or not.
I'm thinking of doing more feed grade ferments, stripping and do a final spirit run. It was not as funky as I figured it would be, actually quite good smell (very buttery) so I pleased with the outcome.
I'm going to continue to use this recipe for my rums and will also try 1 slow run to see if it needs not to be stripped. But for the next few untill I have enough low wines for a 12 gal spirit run I'll strip them.
Now I need to find a good source of brown sugar and another ts to get the molly every other time so not to go there all the time.
Well hells bells, my feed store does not have any more molly and I can't find any dark brown sugar. I need to find a constant supply of both without going over the web, I don't know about anyone else but the less the gooberment sees me buying a shit ton of sugar and what not the better!
I've aired the strip run out for 2 days and now it smells like warm melted sweet butter with molasses.
Untill I find my supply of goodies I'll rest on it for a while, I want to keep on going with rum since this recipe seems to be awesome and I'm sure if I did a 1 run process it would be great as well.
For now I'm going to use a bit of the dunder (20%) and the trub in the fermenter and mix up a batch of sweet feed then once I get the rum goodies I'll go back on that.
I'm going to mix a quart of sf and one of this rum and experiment with it, I'll keep on posting in this here thread for notes just in case it's worth repeating.
Well today I'm running a spirit run of sf with the low wines of the rum and some dunder in the thumper. I kept about 1.5 quart of the hearts of the rum to play with at 145 proof.
I'm at 1.5 gallon and still holding abv at 155 and for now no sign of tails. I'm collecting in pint jars and running a bit faster than usual but not a strip. The flavor is good but not that warm sweet butter of the rum strip.
I've put about 20% dunder in the fermenter for the next rum and will save all dunder from here on out for my pit and future rums, I think I'll use this backset from the thumper in my next sf wash as well.
I have no idea on how much to expect from this run but looks like 2-2.5 gallons then collect to 20% for the feints jug.
I'll keep on posting in this thread on future rums I do to keep notes and progress. As for now I see no change happening with this recipe only how I decide to still it.
I've had this rum to be the best I've ever tasted, white is soo good and the aged is well still aging.
I've played with sugar amounts and moll amounts and the op seems to be by far better, more flavorful and bodied than any other tried.
I've also found the use of dunder to be of no help with flavor and will not continue to use it just because it has no benefit. IMHO
When I come back from my break, I have plans on making a 50 gal rum wash and running in single (with thumper) passes to fill my needs for the coming year.
If anyone has tried this recipe and liked it please post here your results.
And if anyone wanting to try it please ask any questions and I'll help anyway possible.
Like I've stated before this is a very bold and flavorful rum. It has everything I've missed in others and can't find in commercial rums.
I just started another rum ferment 2 days ago and is running wild, I used the same recipe as the op for a 16ish gal.
I'm planning to use dunder from this and start putting it in the thumper with the feints on the next run and also start a pit to infect and hopefully bring out some more flavors.
My attempt at a dunder pit when I originally did this post was a failure I think because of the cold. I should've saved it and seen what the spring and summer would do for it plus it would've been almost 7 months old now and aged a good bit.
Hindsight is a bitch
After this ferment is complete, I'll make another and another. I have a spare 55 gAL fermenter so I'll keep adding to it until I have my needs met.
I'm doing it this way in hopes of getting an infection by the time it's full and ready to run. It should be 3 weeks or so, and it's hot than hell here so it is looking promising.
Shine0n
Shine0n
