Advice needed on Recycling Failed Recipes
Advice needed
I made some Limoncella and Orange Dreamsicle that is just plain nasty. I would like to recycle it. I will be using a pot still, then a reflux still going for a neutral.
It's very sweet and was wondering if,
1) I should add it to a ferment (worried about the alcohol killing the yeast)
2) Strip it with a wash (problems with sugar during strip?)
3) strip it with a spirit run (problems with sugar during spirit run?)
I'm leaning towards #2
Re: Advice needed on Recycling Failed Recipes
I screw up a lot.
I have never tried to redistill a failed maceration. If you do it, I think a heavily diluted strip would be the way to go. Go easy with the heat up and see what happens.
I've stopped fighting my inner demons. We're on the same side now.
I've stopped fighting my inner demons. We are on the same side now.
C2H505 said, "I made some Limoncella and Orange Dreamsicle that is just plain nasty. I would like to recycle it. I will be using a pot still, then a reflux still going for a neutral.
1) I should add it to a ferment (worried about the alcohol killing the yeast)......
I will be doing something the same (pot still).
With the failed liqueurs I will add them to a ferment of something similar, with sufficient water so the alcohol content is below that of the ferment. Won't take much water.
And I have a large batch of marmalade that is terrible; I will add it a bit at a time to similar (mandarin?) ferments, broken down with some water and after the sugars in the ferment are pretty well munched up by the yeast. It will give the ferment a bit of a boost as it uses the sugars in the marmalade.
Don't add to the ferment until it is time to run, then just add to your next run same as you would with fients.
Do calculations to work out the abv of the ferment plus recycling and make sure the ferment will easily go to completion. Add the recycling when the ferment is low on sugar but still active.
Trying to referment a finished liqueur might be just asking for heartache. If it works, that's great. But if it looks like trouble, stalls the ferment or something, I would be inclined to just give up and run it as as, whatever that may be at the time. This feels like one of those deals where I end up with a ton of time invested with little or no improvement. But then, I don't have much trouble with scorching sugar like some guys do, so YMMV.
Thanks for all the help, I'm gonna go with #2 and just divide the failed stuff into a few stripping runs through my pot still.
Depending on the fault and how good your distilling skills are, sometimes that isn't a good idea. Some faults spoil everything you put them in. A couple of bottles of shit you don't like can become ten bottles of shit you don't like. If the fault is acidity because you didn't follow a good method you should be ok because the acid will get left in the boiler, but a flavor issue may carry over and spoil your next strip.C2H5O5 wrote:Thanks for all the help, I'm gonna go with #2 and just divide the failed stuff into a few stripping runs through my pot still.
Just a thought
I hate having to clean unwanted flavors out of a packed column
That's why I avoid redistilling flavored mistakes, such as Limoncella or Orange Dreamsicle
- Truckinbutch
A lot to be said for that wisdom .shadylane wrote:Just a thought
Rub as hard as you want and you still can't polish a turd .
But in the pot still....shadylane wrote:Just a thought
The Baker wrote:But in the pot still....shadylane wrote:Just a thought
Correct, it will be stripped in a pot still then refluxed in my NS Offset with low wines.
The more I think about it, I don't see an issue with it, when I started out, I stripped a lot of my old liquors like peach schnapps...how the hell does someone accumulate so much peach schnapps ?
So your saying that it's not worth it to strip the alcohol from unwanted booze?Truckinbutch wrote:A lot to be said for that wisdom .shadylane wrote:Just a thought
- kiwi Bruce
C2H5O5 what sort of volume are you talking about?
Getting hung up all day on smiles
My experience when you add that small of amount to the next run you do not get the off flavors left in your packing.
3/4 gallon of each, I figured I would split it over three 12 gallon charges, so it would be about 1/2 gallon per 12 gallon charge (actually 11.5g to 1/2g)kiwi Bruce wrote:C2H5O5 what sort of volume are you talking about?
- kiwi Bruce
She'll be right...split it up and run her, Good call!
