Making Cuts
Making Cuts
Got this link from Zymurgy Bob author of "Making Fine Spirits" on another forum he states that it is one of the best articles on cuts, and I have to agree with him.
http://issuu.com/artisanspiritmag/docs/ ... 008_web/27" onclick="window.open(this.href);return false;" rel="nofollow
Re: Making Cuts
Interesting read and sure explains it very well. Thanks, Bushman! Definitely recommend others to read.
- S-Cackalacky
Re: Making Cuts
Might be a nice read if I could figure out how to navigate their publishing application. I can't read it without zooming in and when I do that, most of it disappears from the screen. Is there a regular web page version of the article?
- S-Cackalacky
Re: Making Cuts
Finally found a way to display it in a larger format. Doesn't really go into the "how to" of making cuts, but gives good information about the composition of the cuts and the compounds found in them. The article following that one also seems interesting, but I haven't read the entire article yet - "Resting Spirits".
Thanks for the link Bushman.
Re: Making Cuts
+1S-Cackalacky wrote:Might be a nice read if I could figure out how to navigate their publishing application. I can't read it without zooming in and when I do that, most of it disappears from the screen. Is there a regular web page version of the article?
- S-Cackalacky
Re: Making Cuts
Bear (and anyone else), you can change the page format by clicking the little "page" shape at the bottom right and then zoom, if need be, with the little slide bar at the bottom left. Best way I found to scroll was with the up/down arrow keys on the keyboard. The scroll bar on the screen seems a little too touchy.
Re: Making Cuts
I agree we already know how to make the cuts but it does a good job explaining the chemistry.
- S-Cackalacky
Re: Making Cuts
Bushman, hope you read the second article too - "Resting Spirits". I found it to be of even more interest than the one about cuts. I think we've touched on "resting" here on the forums quite a bit, but never had it as well defined as in this article.
Re: Making Cuts
Interesting that someone has a patent on adding ethyl acetate to young bourbon to make it taste like old bourbon. I hope no ones really doing that! Ethyl acetate is an ester of ethanol and acetic acid and is formed in the barrel over long term aging. I would never add any foreign BS into a whiskey, but it is fun trying to find a way to prod mother nature along faster LOL (HD's nuke threads, dildo threads, oxygenation, heat cycling etc etc etc)
Re: Making Cuts
Haven't finished it but will do so after the 4th!S-Cackalacky wrote:Bushman, hope you read the second article too - "Resting Spirits". I found it to be of even more interest than the one about cuts. I think we've touched on "resting" here on the forums quite a bit, but never had it as well defined as in this article.
- humbledore
Re: Making Cuts
Very interesting thanks for posting!
B
B
