It's still a ponu. I'm just utilizing 4 ea .375" diameter tubes as my primary vapor tube instead of one 3/4". The initial vapor travels up these tubes and back down through the condenser, condenses back to liquid and then will hit the lower coil (not installed yet) and flash off into the secondary coil (this one is installed) and come out as product. I went with 4 ea 3/8" tube to keep it uniform and I would have had to offset the tower to one side to fit a 3/4" piece of pipe..4-3/8" tubes have the exact same surface area as one 3/4" (2.355 sq inches). Thanks again for the compliments, I'm going to try and get her sweated up by weeks end. But with summer here kinda makes it tough..
OK, Till now I understand, Steamchamber, primairy steamtubes (4, looking great! ) going on top into the condenser, into lower coil. Output throug cooiling coil. Still the same as the ponu, but what are these big holes? And when you build the inside (4 tubes connected to the lower coil) pleas send pics!!
Henk
Henk
Ambachtelijk Destileerderij Nes (Artisan Distillery Nes) To conquer death, you only have to die
Well, wife is out of town, kids are with the cousins, it's rainy and shitty out, beers are cold and the tunes are loud... These are the elements for progress....Things left to do: install cooling line ports, secondary vapor tube, install parrot.....Getting close..
