And because some states no longer allow its use due to its being a secondary source within water supplies... And because excess zinc can cause organ damage, primarily the pancreas as I vaguely recall...Dan P. wrote:The plumber said; "err... because it's impossible to solder, because you can't cut it without negating the effect of the galvanizing, because it's heavy, thick, and a has no viable use when copper pipe is readily available".
-Dan
You see, I have researched it enough to know I won't use galvanized pipe or anything else with large amounts of zinc... But that doesn't mean I bookmark everything I read so I encourage anyone else concerned or otherwise to do the same... I do more than my fair share of research on a daily basis for my own and my paying customers needs...
And I think the following statement made by the plumber sums it up well...
the plumber wrote:and a has no viable use when copper pipe is readily available
