Simple 2" pot still using A type keg spear valve to connect
Post your builds here.
maheel
Post by maheel »
A while back some one posted up asking about using different ideas to connect 2" to a keg
thought someone else might like the idea if they need it :)
using a A type keg and valve is something i suggested at the time
the lump of pipe was siting around looking ugly so i turned it into a pot head.
I cut the valve on the red line and filed it a little on the yellow
i flared the 2" copper a little and hammered the valve up there
soldered it in and there you go
a bit of thread tape and it will seal no drama (or the flour paste)
NcHooch
Re: Simple 2" pot still using A type keg spear valve to conn
Post by NcHooch »
Nice! .....did you use a hacksaw for cutting the flange off? ....if so, that must've been a pain.
NChooch
maheel
Post by maheel »
yeah hacksaw
but once you break into the inner circle hole it cuts pretty quick
but i did another with the 5" grinder and a 1mm cutting disc (much easier :mrgreen: )
emptyglass
Location: Victoria, Australia.Usually the shed. Sometimes the cellar.
Post by emptyglass »
Good job mate. Nice tip for the folks here.
D style are more common for me, those A style ones look easy.
