Been doing some tweaks to my Still setup, gleaned this idea from "ProChargedHarley03" page 3 of this thread http://homedistiller.org/forum/viewtopi ... 5&start=60
Had some scrap plywood that I used , I used a 32 gallon brute lid for the circle, didn't feel like getting all complicated.
Cut out with a jigsaw, marked the center and used a hole saw for the middle then cut in half, stained both sides with some Red Mahogany and sealed the top with a spray varnish.
Lined up the pieces and used a biscuit joiner and dry fit biscuits to keep the pieces flush when put together.
Quick Table
Re: Quick Table
Then I secured the table with wire and did a dry fit.
Re: Quick Table
Added some table clamps for a snug fit and easy on and off setup.
Re: Quick Table
I'm very happy with how well the table fits, it's very secure and quick and easy to install and remove, I will be putting on a few layers of polyurethane and polishing up a bit after my fall run.
- rgreen2002
Re: Quick Table
Looking good C2... I really gotta get on this!
If the wire fails you, maybe a hook and eye setup.
EDIT: ...or what you have apparently done....LOL. I somehow missed that last post!
HD Glossary - Open this
