3" Flute build
3" Flute build
Hey all. Just finished up making a pot still head for a couple friends and it kinda got me in build mode. Been sitting on a bunch of stuff salvaged from the scrap yard and it's time to do something with it. A friend of mine has also been getting at me also. So after reading through the flute talk thread twice, whew, and linking to some of the build threads there, I think I'll give it a shot. Looking through all the parts it appears I have damn near everything I need for a build. So here it goes.
Here are a few pics to get started. Remember, Rome wasn't built in a day and neither will this flute, haha. So bare with me on this one. I did get it moving in the right direction. Might as well post the pic of the pot heads for my friends. **Pics look a little off after resizing. I'll have to work on that.
Re: 3" Flute build
Column -3"x 24"
Dephleg.- 3"x 5" . - 4.5"l. x 1/2"dia.
Prod cond.- 2"x 20". - 20 1/4"l. x 3/8"dia
Sights - 1 1/2"
4 Perf plates w 1/16" holes, 1/2" downcomers to 3/4" caps.
15.5gal. keg boiler. Converting my keg to elect.
Sights - 1 1/2"
Re: 3" Flute build
Cut out a couple plates and turned them down on the drill press with a file. Soldered plates and tubes. Next I guess will be product condenser then water test both of them at the same time. Hopefully soldering the P.C. goes a little smoother than this one.
- rgreen2002
Re: 3" Flute build
Coming along nicely Pooch. Looking real good. Are you going to make the plates removable?
HD Glossary - Open this
Re: 3" Flute build
Looks like you have the skills to make a nice looking bubbler Poochy, shame you didn't go the extra inch and build a four incher. I think you will tire of the slow output of a three fairly quickly.
Re: 3" Flute build
Plates are going to remain stationary, build will remain one piece with no breaks.
Went with 3" being that I already have it. Scrapyard find. Was unable as of now to find a piece of 4". Could always be build number two after I learn how to drive this one
Re: 3" Flute build
For $8.00 I ordered a tri-clamp for my keg connection that came with two ferrules and a gasket off eBay. Have wire to make flange but figured I'd give this a go. Tig welded right up with silicon bronze.
Here it is shined up.Re: 3" Flute build
Went ahead and cut out 4 plates for tree. Damn drill press won't hold 1/16" bit so used the cordless. Not as bad as I thought it would be. Taped all 4 together, punched top plate and proceeded to drill. No lubricant, barely any trigger and moderate pressure. Three bits used, only broke one when I could tell it was getting worn by having to push a little harder. So I made sure to swap out the other one after about 30 or so more holes. Took about 12-15 seconds a hole. Was counting only to keep my head in the game. Theres 86 holes, but I have to ream the half inch hole out to 5/8. After that I'll add a couple more around it. Should end up with 90/92 total. Here they are.
Re: 3" Flute build
Made a little more progress. Here's some random pics, everyone likes pics. I'm sure you seen them before in other builds. But browsing different pics of the same things is what has helped me out so far. Ended up shortening the vapor tubes in the shotgun by 3" so they will be recessed on each end so when I solder on end fittings I lessen the chance of screwing up the seal on the end plates. Probably not I problem but did it regardless. Decided on the suspended cups only to increase the hole count on the plates. Spacing is 4.25" on tree.
Re: 3" Flute build
Spent some time in the garage and made some more progress. Both condensers are water tight Saw was only 2.5" so a little filing to get a good fit on adapters. Yet to drill holes through. Slow and steady progress. Hoping not to miss a step somewhere.
Re: 3" Flute build
Glad them solder joints on sights came out lookin pretty damn good............cuz now I have to heat them and pull them off. Was sitting here thinking and it pops in my head I forgot to put the nut on. In my last post I says " hoping not to miss a step". Can only laugh. They did look good though
- Fart Vader
Re: 3" Flute build
Very nice work pooch.
Congratulations.
Congratulations.
My double walled boiler build: The Mashimizer. viewtopic.php?f=50&t=64980
Re: 3" Flute build
All fixed up
[attachment=0]IMG_20170128_153542386-480x800.jpg[/attachmen
Re: 3" Flute build
Clean up and test fit everything. Have to wait on a 1 7/8 whole saw to cut glass. Can't find one locally. Next I guess is figure out how to run plumbing. Thinking all 1/2"copper. Kinda like that look I've seen without any plastic tubing.
Re: 3" Flute build
Looking good Pooch..
Unfortunately, all the good work of cleaning it up will have to be re-done.. a well, good experience at cleaning
Lookin good, keep her coming..
Mars
Mars
– Albert Einstein
– Albert Einstein
Re: 3" Flute build
Unfortunately your right. Cleaned it up on the 8" wire wheel mostly to get out all the scratches and rough stuff. Should make the final clean that much easier. Removing the discoloration from final assembly I'll probably use the polishing wheel and a light copper polish. Make it shine properly.
Re: 3" Flute build
huh? looks like we're going for the same thing but you're further ahead of me. I still need to source sight glasses(borosilicate) and find a way to cut my chamfer on the adaptors , that is a pretty lookin rig tho kinda like envisioning my thoughts .
good luck dude
bronctoad
good luck dude
bronctoad
Re: 3" Flute build
Got some garage time in to work on my build. Built controller, welded a couple 2" ferrules in the keg, made a parrot and soldered up final assembly. Final step will be to install water lines and valves. Decided to just get glass from a local business and not get the hole saw. Now waiting on some cork for gaskets. Couple clamps should be here in a couple days and I believe that will be it, haha. Sure something else will come up.
The 220 running to my garage is only 20amp service 12/2 wire. Pulled out the wire from around the house and picked up 10/2. Need to reinstall that hopefully in next few days. Maybe by next weekend it will be ready for a cleaning run. Here's some pics. Again, nothing new, everything is borrowed from other builds here, just sharing. Thanks to all who posted Thier builds so as I am able to build mine.
Re: 3" Flute build
Working on water lines.
Re: 3" Flute build
Awesome looking build and inspiration for when i step up to a keg rig
Re: 3" Flute build
Well, this happened. Internal leak when checking cooling system. Cut , repair/rebuild, resoldered. Hope all goes well later when I Run another hydro.
Re: 3" Flute build
Nice looking machine. Well done. Cant wait to see how it works for you!
........WHY?.....Because I can......
My 4 inch Hybrid 2 Stage Build. . .
The Cooling Tower Project
My 3" Valved Flute Build. . .
- rgreen2002
Re: 3" Flute build
DAMN SON....
She's a beauty....
She's a beauty....
