4" bubble cap column
I finished my 4" column today and am very excited to see how it performs. A big thanks to Olddog and Samohon for the inspiration and plans. I am reusing the dephlegmator and shotgun condenser from my previous 2" packed column. I have the materials to build a 4" dephleg but am curious to see if the 2" I have will work, I think it will. My first sacrificial run is going to be some Birdwatchers sugar wash. Once I learn how to drive this thing I planning on making some bourbon and rye. I scorched my first attempt at an all grain potato vodka so I hope the bourbon and rye turn out better than the first AG attempt.
- Oldvine Zin
Re: 4" bubble cap column
Nice looking build But not sure if I understand how the plate disable system works?
OVZ
OVZ
Very nice mate . Love the work on the plates, another member yummyrum did some.of olddogs Weirs too, says they work well from.memory, always wanted to try them but look to hard to.make. Good luck with the run.
"Homer J Simpson"
"Homer J Simpson"
Very nice work with building of the column.. but confused about the plates.. are they just staking one on top of the other in the column ??
Keep us informed on how it works.. especially the 2" reflux condenser..
Mars
Mars
– Albert Einstein
– Albert Einstein
Nice! Where would I find the plans and specs for those bubble plates?
long live Oldsmobile Aleros
Nice job nconner ... I'm sure you will be very happy . LOL I recon is probably impossable to flood those down comers , while operating this still you will never come close .
http://homedistiller.org/forum/viewtopi ... 17&t=20947aircarbonarc wrote:Nice! Where would I find the plans and specs for those bubble plates?
Those down comer trays remind me of the ones in oil and gas towers.Yummyrum wrote:Nice job nconner ... I'm sure you will be very happy . LOL I recon is probably impossable to flood those down comers , while operating this still you will never come close .
Thanks for the link!
No worries ... well strangley enough the same technology is used in most commercial distilleries tooaircarbonarc wrote:Those down comer trays remind me of the ones in oil and gas towers.Yummyrum wrote:Nice job nconner ... I'm sure you will be very happy . LOL I recon is probably impossable to flood those down comers , while operating this still you will never come close .
Just that we have seen so many flute builds done with round tube downcomers that maybe we have forgotten .
I have to admit that Olddogs mark two was my inspiration too .
Although I went with perforated plates , I made his weir downcomers with the smiley face
I hope you find the plate disabling useful nconner1 . I opted for modular but am always having to brake it downandbuild it up ..... plate disabling would have been so much easier.... guess the olddog was onto a thing or two
If you want to disable a plate you open the valve for that plate and it will drain back into the boiler. If you close the valve above the trap the liquid from the upper disabled plates can be directed to the lowest open plate. I'm not sure how often I will direct the liquid to other plates but I thought it might be nice to experiment with.Oldvine Zin wrote:Nice looking build But not sure if I understand how the plate disable system works?
OVZ
The weirs alternate sides so one side will have the bottom of the weir on the top of the plate and the other side will have the dam.StillerBoy wrote:Very nice work with building of the column.. but confused about the plates.. are they just staking one on top of the other in the column ??
Mars
- Oldvine Zin
OK the p trap had me confused and I thought that a three way valve would be better suited for plate disabling.nconner1 wrote: If you want to disable a plate you open the valve for that plate and it will drain back into the boiler. If you close the valve above the trap the liquid from the upper disabled plates can be directed to the lowest open plate. I'm not sure how often I will direct the liquid to other plates but I thought it might be nice to experiment with.
Good luck and tell use how she runs
OVZ
Haven't thought of doing that before.nconner1 wrote: If you want to disable a plate you open the valve for that plate and it will drain back into the boiler. If you close the valve above the trap the liquid from the upper disabled plates can be directed to the lowest open plate.
Keep on experimenting
