Got Any Tips For Re-soldering A Cap ?
Post your builds here.
olecajun
Post by olecajun »
I have a 5" copper cap that I heated up to replace the sleeve part, so I am reusing the flat sheet piece of the cap lid. Any tips before I attempt to re-solder it ? Cleaning method , wire wheel brush , or ???? Thanks in advance for input.
Gator Meat ;; Its whats for dinner
FreeMountainHermit
Re: Got Any Tips For Re-soldering A Cap ?
Post by FreeMountainHermit »
I used to solder stainless fittings for a living (silver) if that means anything. When we replaced/repaired joints it was very easy to apply solder to the joint and apply heat using a slightly carburizing flame until the flux ran clear then apply silver. Done.
Blah, blah, blah,........
googe
Post by googe »
Vague discription lol. But any time you resolder, make sure it's clean, old flux can be oily, hot soapy water and a scrubber.
"Homer J Simpson"
olecajun
Post by olecajun »
Sounds good. I plan on putting some heat to the old soldered piece and using a small stainless tooth brush to brush it off when it melts , then scrub it with dawn. Just not sure if I should wipe it down with denatured alcohol or something. :econfused: Thanks again for the input.
T-Pee
Post by T-Pee »
Wiping with isopropyl will remove the old flux then resolder as necessary.
tp
FreeMountainHermit
googe wrote:Vague discription lol. But any time you resolder, make sure it's clean, old flux can be oily, hot soapy water and a scrubber.
Vauge ?? Not really,Sir. Simply the way it was done every day.S.O.P. Did many, many hundreds possibly thousands in such manner using Oxy-Mapp. Even black ugly burned flux can be "cooked" away but it takes a skilled hand as failure is but a blink away.
Gotta admit tho' that most hobbiests (sic) don't have access to an Oxy-acetylene- MAPP torch.
olecajun
Post by olecajun »
Yea I have both here at the shop. I have a small machine shop and have quite an assortment of tools. Everything from torches, plasma cutter, lathe, mills , drill presses, welders. Not saying I am good at anything, just have a lot of tools. :)
cob
Post by cob »
did you do the original soldering ?
if not has the original solder tested for lead ,
or proven to be lead free ?
googe
Post by googe »
Wasn't referring to your comment fmh.
"Homer J Simpson"
FreeMountainHermit
googe wrote:Wasn't referring to your comment fmh.
Sometimes it's difficult to know who's talking to whom. Go in peace my friend !!!
:thumbup: :wave: :)
olecajun
Post by olecajun »
Yea I know it was lead free solder, a friend did it and lives 500 miles from me. I am changing it from a slip joint to a clamping joint. After I did all that cleaning, it dawned on me , duhhhh, :roll: flip the piece over and clean and solder the other side to the sleeve. Its never had solder on it. I tell you one thing, that paste flux is nasty to clean off after the fact. So now I got that piece done I have to remove the collar from the pot and clean and re-solder a new heavier collar that has the flange tig welded to it.( Never knew copper and stainless could be tig welded. )
Oldvine Zin
Post by Oldvine Zin »
olecajun wrote: I tell you one thing, that paste flux is nasty to clean off after the fact.
And folks wonder why we insist on full cleaning runs after soldering :roll:
OVZ
olecajun
Post by olecajun »
Yea that paste flux is like trying to wipe lard out of a cold skillet, it just keeps smearing.I have several kinds of flux for silver solder and lead free solder so is any type better than the other ? Liquid vs Paste ? Thanks
Oldvine Zin
Harris stay-clean liquid flux :thumbup: :thumbup:
OVZ
olecajun
Post by olecajun »
I think I have some of that. Thanks for the input.
