deer log (bologna)
Place for any food recipes that ya want to share
deer log (bologna)
Postby jedneck » Fri Oct 28, 2016 2:30 pm
10#sugar
3# salt
.4 # pepper
.25# nutmeg
.20# mustard powder
.25 cure ( i use heller's modern cure)
.5# smoke flavouring (i use ac legg's smoke flavouring)
this is enuf for 100 lbs. use .14lb per lb of meat
grind meat 2x though a 1/8 inch plate and mix seasonin with meat till mixed. stuff in casing and put in oven set at 170 till internal temp is 155.
or omit smoke flavour and smoke till internal temp is 155. keeping smoker at 170. size of casing will determine how long it takes. I use a 4 inch case and it takes 7-9 hours.
Willtry to answer any questions.
big help
Dunder
jedneck
Re: deer log (bologna)
Postby FreeMountainHermit » Fri Oct 28, 2016 2:42 pm
jedneck wrote:this is enuf for 100 lbs. use .14lb per lb of meat
Didn't register. Up all night so slept all day. Just now drinking "morning coffee"
Blah, blah, blah,........
FreeMountainHermit
Postby bitter » Fri Oct 28, 2016 5:08 pm
Darn that sounds tasty!
bitter
Postby jedneck » Fri Oct 28, 2016 5:25 pm
when the seasoning/cure is mixed it will make enuf to do 100 lbs of meat. use .14 lb of mix per 1 lb of meat.
if recipe is scaled down measure the cure carfully
works good with deer or beef
big help
Dunder
jedneck
Postby Bigbob » Fri Oct 28, 2016 5:56 pm
Thanks Jed! I still think of that log at your place and sheds. Good eats!! :wave: :thumbup:
viewtopic.php?f=15&t=62150 How I run a small still
Bigbob
Postby jb-texshine » Sat Oct 29, 2016 1:42 am
Jed,i dont guess you got one for jalapeno cheddar summer sausage do ya?
Deo Vendice
jb-texshine
Master Distiller
Return to Favorite Food Recipes
Who is online
