2"-3" triclover sourcing
Research sources, reviews and links to information relating to distillation.
UnSub
Post by UnSub »
(I really must be inept at using a search engine, I'm admitting it now)I have been reading A LOT on this form and just seen someone mention a source for the keg-to-3" triclamp reducer that was much cheaper than Brewhaus et.al. I need the clamps and seals to attach 3" boka build to this 15.5 sanke keg. Honestly, I have been looking for a while and can't find it- can someone help a brother out?;)
Regards,
UnSub
jedneck
Re: 2"-3" triclover sourcing
Post by jedneck »
http://www.glaciertanks.com/TriClamp_Pr ... ucers.html" onclick="window.open(this.href);return false;" rel="nofollow
big help
Dunder
FreeMountainHermit
Post by FreeMountainHermit »
The cap style reducer offers a little less height as well as being a couple of bucks cheaper.
https://www.brewershardware.com/Tri-Clo ... 30X20.html" onclick="window.open(this.href);return false;" rel="nofollow
Blah, blah, blah,........
Swedish Pride
Post by Swedish Pride »
Ali express is the same, only difference is that you get to wait for a month to get it
http://www.aliexpress.com/item/76MM-to- ... 18400_6148" onclick="window.open(this.href);return false;" rel="nofollow
Don't be a dick
varocketry
Post by varocketry »
Best source I've found by far is a chinese vendor selling direct on EBAY. I've used him several times.
http://www.ebay.com/itm/SANITARY-ASSEMB ... xycmBSsx55" onclick="window.open(this.href);return false;" rel="nofollow
http://www.ebay.com/itm/8-End-Cap-8-Wel ... SwBLlVExa9" onclick="window.open(this.href);return false;" rel="nofollow
-Just need something else to build. -
Not at all the best prices.
Snackson
Post by Snackson »
varocketry wrote:Best source I've found by far is a chinese vendor selling direct on EBAY. I've used him several times.
Their stuff doesn't match up to standard sizes I have found. For example, ordered the 6", soldered it up, bought a 6" reducer from Glacier and they are different sizes. I would avoid the daily appliance vendor. Buy from Larry, at least there you have quality service from a reputable vendor.
Hank Reardon
Post by Hank Reardon »
I mistakenly did the Chinese version. Both clamps have failed (all thread bent). I have ordered fro SD and received premium quality.
The ones you want are those that have a hole through the thumb handle.
