Fermented goods....mmmm...
I just bottled half a 23l batch of medium show mead this evening. The other half went into a 3 gallon carboy with some fresh blackberries i picked from the garden today and some local blueberries i picked up yesterday. I've got a 23l batch of gewurtztraminer that has cleared and is ready to be racked again before bottling. My "to be distilled" is a 23l sugar wash that has been trucking along very nicely. OG 1.090, down to 1.050 now. i also have about 12l of blue agave syrup based wash. it's fermenting very slowly. even slower than a stubborn mead. but i have faith. going for a tequila type liquor but don't think it'll taste anything like tequila. i couldn't help but try when i saw this stuff at costco. a bit of an experiment i guess. i'd love to try to distill some mead sometime but it's hard to pour all that great flavour down the drain once you get the alcohol. anyone tried this? mead brandy? krupnik?
- Attachments
Re: Fermented goods....mmmm...
You lost me with the marbles. Is there a reason why you need to fill it all the way to the top?
RD
RD
you don't want your wine to oxidize (limp/flacid taste). so putting the marbles in takes up the airspace in the carboy without watering the wine down with water. if you have extra wine around you can just add that, but the marbles allow you to take up airspace regardless of what you're fermenting.
you lose a little wine every time you rack it do to sediment. and you need to rack it a few times depending on the recipe/kit/method
I learn something every day. So in mead this is important because you might rack 3 or 4 times and buy that time there wouldn't be a co2 blanket. Is that a correct assumption?
exactly. it's amazing how fast it happens aswell. even just a bit too much splashing when you're siphoning will oxidize your mead/wine. still tastes fine but with more gym-sock. it's the same principal as airing out your fresh liqour i guess. just in mead and wine you want to keep those flavour filled volitile compounds
So if a guy doesn't have 50lb of marbles do you think injecting co2 into the bottom of the fermenter would do the same thing?
yup. it would work. i found the marbles we're cheaper than tanks of co2. however it would be nice to fill the carboy with co2 before starting to rack
maybe a little overkill though.
Oh and to answer your question yes I have distilled honey 3 times so far and it's scary good. The first time I did it i tried a slow single run and it was overpowering, I added blueberries to it and cut it to 40%. That stuff turned out nice. The second a time was a double run and the third was a thumper run. They both turned out nice.
I would suggest you try it.
I have a shit load of co2 that's a good idea. I'm going to try that on the next beer I do.
well i'll have to try it. sounds like it's worth it. it's getting harder and harder to find cheap honey though. need some beehives i guess.
