RumBrewer's blurtings!
Re: RumBrewer's blurtings!
Postby RumBrewer » Fri Apr 06, 2012 9:25 am
WELL, I've been pretty lazy on the likker front.
I have some cuts to blend, and I've got 10 gals of ujsm to run.... Then I should be caught up.... and then I'll need to get busy brewing!
Everything I do or say may or may not have really happened... or it may or may not be all bull shit!
Turning money into steam and likker 10 gallons at a time!
I just want Uncle Sam to be more like Uncle Jessy!
RumBrewer
Postby RumBrewer » Fri Apr 06, 2012 10:36 am
CRAP!
Blended 1 jar too deep into the tails!
RumBrewer
Postby astronomical » Fri Apr 06, 2012 11:56 am
I can't wait to start brewing... Probably do my first ag beer next weekend. I may do a hefe weisse, not sure yet. Are hefe weisses a bad starting beer?
astronomical
Postby RumBrewer » Fri Apr 06, 2012 8:48 pm
astronomical wrote: Are hefe weisses a bad starting beer?
Certainly NOT!
Just be prepared for a slow sparge if you're using wheat.
If you've not gotten your grains yet, get a handful of rice hulls for your grist. They will significantly help loosen the glue that you'll make and keep you from getting a stuck sparge.
RumBrewer
Postby fullhouse » Thu Apr 12, 2012 1:01 am
4 am and cant sleep reading old posts that i missed :yawn:
3' Essential Extractor PSII High Capacity (Brewhaus) on gas,recirculating 60 gal olive barrel for cooling
Employ your time in improving yourself by other men's writings, so that you shall gain easily what others have labored hard for ~ Socrates
fullhouse
Postby astronomical » Thu Apr 12, 2012 1:16 am
fullhouse wrote:4 am and cant sleep reading old posts that i missed :yawn:
same here..
Today I'm making that hefe that I was talking about a few posts up... I took Rum's suggestion and grabbed some rice hulls as well. All very exciting.
astronomical
Postby RumBrewer » Fri Apr 13, 2012 8:14 am
Gurrr! Just spent 4 hours super cleaning the kitchen (Between last night and this am.)
Now I want to run the still... but not sure if I want to make a mess in the kitchen again!
#Firstworldproblems
RumBrewer
Postby RumBrewer » Fri Apr 13, 2012 9:54 am
For whiskey... I do like this CM still with a 3/4 packed column. It pumps out at 75-80% for the whole run and plenty of flavor too.
It took some time to get it all dialed in, but that's half the fun right????
RumBrewer
Postby blind drunk » Fri Apr 13, 2012 10:17 am
RumBrewer wrote:For whiskey... I do like this CM still with a 3/4 packed column. It pumps out at 75-80% for the whole run and plenty of flavor too.
Is that on a single run or a double? Thanks.
blind drunk
Master Distiller
Postby RumBrewer » Fri Apr 13, 2012 10:45 am
blind drunk wrote:Is that on a single run or a double? Thanks.
I'm pretty much down to single runs unless something funky comes through.
When I get things right, man they are good! When I screw it up somehow.... I end up re-running... or just adding back to the next run.
Oh... and I lied. This batch is running off at about 89% -91% right now.
RumBrewer
Postby RumBrewer » Fri Apr 13, 2012 1:40 pm
Woah Balls!
Even the tails are coming through at 87%!
Most of this run was at 74 degrees and 90-91%, then the temp started climbing over 600 ml of distillate. Now at 84% and 84 degrees!
Tell me again why I need to build a boka? I need something to STRIP with at this point!
RumBrewer
Postby blind drunk » Fri Apr 13, 2012 3:28 pm
Sounds good. How tall is your CM? Thanks.
blind drunk
Master Distiller
PreviousNext
Return to Off-Topic Discussion
Who is online
Users browsing this forum: Bing [Bot] and 2 guests
