does someone know how to seal and glue glass-copper or glass-brass?
it should be alc. proof and not dissolve.
i have a alc.-meter without the weight section,(broken of) and i want to use a copper or brass cap as a weight.
i dont want to save money,just try to repair it for fun.
i have heard of water-glass,would that do the trick?
seal glass to copper
if you don't want to do time,
don't do a crime!
and as a finishing touch,
god created the dutch.
don't do a crime!
Re: seal glass to copper
If it works it should be safe enough if it's properly cured and rinsed.="dutch@home"
Sodium silicate (water glass) breaks down to silica and sodium carbonate when exposed to carbon dioxide in the air.
Probably a long dead thread but I am also interested in this and have dug up a few copper to pyrex seal articles
http://imajeenyus.com/vacuum/20100923_h ... nner30.pdf" onclick="window.open(this.href);return false;" rel="nofollow
http://www.twi.co.uk/content/ceramics_glass.html" onclick="window.open(this.href);return false;" rel="nofollow
2" Boka on a sanke and a 4" 6 plate flute (learning setups)
Current setup
Wall mounted steam stripper
Wall mounted 6 plate "flute"
50 gallon immersion heated mash kettle
Current setup
and here is somewhat of a step by step
http://www.youtube.com/watch?v=OWw32BLodjY" onclick="window.open(this.href);return false;" rel="nofollow
Current setup
Current setup
You can use a no hub coupling. Only pull the rubber out and replace it with two layers of cork, so the seems are opposing. I've done a couple of glass pipe connections this way....Won't work for what your doing, but it works on a larger scale...
My interest is in development of an internal sensor tree using a small section of Pyrex in between the main body of the tree and the actual sensor. This is to provide some thermal isolation as well as a window an led could be mounted in for lighting the plate.
Current setup
Current setup
