iStill One
Re: iStill One
Assembly street for our iStills 2000 NextGens!
Regards, Odin.
Regards, Odin.
Re: iStill One
And here are two pics of the new 100 liter / 26 gallon units we are producing. For product development and small scale production.
The first picture is the boiler just after its acid bath cleaning. The other picture zooms in on the drain.
More pics on finished product later.
Regards, Odin.
Regards, Odin.
Re: iStill One
That is a nice size for a homedistiller, I am guessing if a person could hide the column most folks wouldn't recognize the square design as a boiler for a still! Very unconventional.
Re: iStill One
Thanks Bushman, yes, perfectly suitable for the homedistiller as well. First three boilers are ready. Pics in a few hours. Column design is ready as well. We start building them tomorrow.
Regards, Odin.
Regards, Odin.
Re: iStill One
Two iStill 100 NextGen Boilers!
Regards, Odin.
Regards, Odin.
Re: iStill One
Designing the column and cooler ...
Regards, Odin.
Regards, Odin.
Re: iStill One
Building the heating systems ...
Regards, Odin.
Regards, Odin.
Re: iStill One
geez Odin, you could buy that guy a table and chair to work at.
the new gear looks awesome!
now i drink for evil.
Re: iStill One
And this is the new 100 liter boiler next to a 500 and 2000 liter unit we are currently automating.
Regards, Odin.
Regards, Odin.
Re: iStill One
Cheap shit me!HDNB wrote:geez Odin, you could buy that guy a table and chair to work at.
In fact, he loves to work like that. There is a table available for him, but he does not use it, HDNB!
Thanks for the kudo's, glad you like the looks.
Regards, Odin.
- MichiganCornhusker
Re: iStill One
Ha, look at that little feller, that's really thinking inside the box, Odin.Odin wrote:And this is the new 100 liter boiler next to a 500 and 2000 liter units
Your products look great.
Re: iStill One
Thanks Mich! You know how much I like to think inside the box!
Regards, Odin.
Regards, Odin.
Re: iStill One
Absolutely beautiful products.
Re: iStill One
Here's a picture of a still that'll go to the UK next week. For whisky and gin production. 2000 liter net capacity. Potstill column that still needs to be insulated.
Regards, Odin.
Regards, Odin.
Re: iStill One
Great looking boilers Odin!
Using Google Search
Using Google Search
Re: iStill One
Pictures of PLC and heating elements ...
Regards, Odin.
Regards, Odin.
Re: iStill One
Short movie of the machine we make our oversized SPP with ...
https://www.youtube.com/watch?v=89KBwyoRT5Q" onclick="window.open(this.href);return false;" rel="nofollow
Regards, Odin.
Regards, Odin.
Re: iStill One
Testing ...
Re: iStill One
Longer pleaseOdin wrote:Short movie of the machine we make our oversized SPP with ...
Regards, Odin.
If I was to win the lottery, Odin, I'd be a customer of yours in a heartbeat
Re: iStill One
Thanks! Here are two more pics. One of the machine, the other of some new test batches we did on our revised big SPP.
Regards, Odin.
Regards, Odin.
Re: iStill One
Partir, c'est mourir un peu!
Here's an iStill 2000 NextGen (almost) on its way to a new and happy craft distiller.
Regards, Odin.
Regards, Odin.
Re: iStill One
... and some pics of the iStill 100 NextGen. 100 liter boiler with 3 inch column (in this case). Column management system (manual option here) and 3 inch column cooler.
Regards, Odin.
Regards, Odin.
Re: iStill One
Cleaning run on the iStill 100 NextGen ...
Regards, Odin.
Regards, Odin.
Re: iStill One
That sure is a tidy little set upOdin wrote:Cleaning run on the iStill 100 NextGen ...
Regards, Odin.
Re: iStill One
... and we are building many more of them. These are the 100 liter / 26 gallon versions.
Regards, Odin.
Regards, Odin.
Re: iStill One
Fun times ahead! Tomorrow, early in the morning, I fly to the Baltics to open a distillery. I'll be back home on Sunday. On Monday we'll start the automation project on the iStill 100 NextGen. We have already made like all the decisions on what we want and how to do it. More fun after that? Yes! Working on a new kind of column for our 5000 liter still. Thinking about doing something weird with perforated plates. 8 to 10 inch column. Two or three plate configuration, LM, not CM, for column management.
Regards, Odin.
Regards, Odin.
Re: iStill One
Doing some test runs on the iStill 100 NextGen. On a 30% low wines charge, she produces a little over 6 liters per hour in pure 96.5%. If I open her up and go for taste in stead of purity, I get 9 liters per hour. This is a manual version. The robotized iStill 100 NextGen is faster yet. 6 liters at 96.5% or 9 liters taste rich at 70% ... very happy with the results. Especially because it's just a 70 mm diameter column (slightly under 3 inch) with 3.5 kW. Because the new big SPP I designed holds a lot of energy, it goes to 77 C in one go. Even without stabilizing. It does not need time to reflux to get to lower temperatures. The advantage of this is that, since even the first part, without refluxing, is already well concentrated in heads, you an start drawing off heads right away. No need for extra stabilization time with the needle-valve closed.
Regards, Odin.
Regards, Odin.
Re: iStill One
Last weekend I tested some new innovations on the column of the iStill 500 NextGen. That's a (net) 500 liter (130 gallon) system for pretty much any product.
On an 18% boiler charge (400 liters), I could get over 16 to 18 liters of pure azeo per hour. That was on 60% power setting. 60% of 18 kW total system's power, so 10.8 kW.
The new design has much more performance to it. I tested column stability and could take the unit without issues to 70%, 80%, and 90% total power. Only at a whopping 18 kW did we encounter column flooding. Pushing the power to 90% would push the output to around 25 liters per hour.
Regards, Odin
Regards, Odin
Re: iStill One
Reorganizing and relocating production to the beautiful city of Woerden in the Netherlands has been a great decision. First of all, I actually live there, so travel time is now just 5 minutes. Four minutes if I take the Nissan Z Car .
Secondly, it allowed us to hugely improve in build quality. We are aiming to deliver the best build units in the world. Longevity goal is 30 years at 24/7 operation. We second that by a 10 year warranty on the units. If you find this interesting, and want to read more, please see: https://istillblog.wordpress.com/2016/0 ... fits-odin/" onclick="window.open(this.href);return false;" rel="nofollow
Thirdly, it allowed me to work out some new ideas. Integrating mashing, fermenting, and distilling for instance. A new approach to boiler design and agitation. And it enabled me to get the whole column redesigned in such a way that it now pushes out around 50% more product per hour. Also functionality and systems integration is up. The units can for instance now be monitored and managed remotely via the internet. We, from HQ, can take over the unit to help out with recipe development. And there will be (yet to be released) a product library where customers can discuss and even trade recipes.
Lots of fun stuff going on here!
Regards, Odin.
Regards, Odin.
Re: iStill One
All good Odin...be careful in that Z!!!
DSP-AR-20005
DSP-AR-20005
