Modifying a Corona/Victoria grain mill
I snapped a bolt inside the auger on my first one.
I stripped the threads in the auger on my second (this afternoon).
So, while I was reminding myself how much I dislike grinding 13 lbs of corn by hand I wondered: has anyone tried grinding down the handle-end of the auger so that it can be driven directly by a 1/2" electric drill ? That is, rather than chucking the bolt you chuck the end of the auger itself. I think it could work and , while I don't have the right tools for the job, I think I can at least make a proof-of-concept model.
________________
- Appalachia-Shiner
Re: Modifying a Corona/Victoria grain mill
I broke a bolt or two on mine till I bought a Grade 8 bolt and chucked it up.
Not saying you won't break a Grade 8 but I have Not yet. But I did coat the threads liberty with Anti Seize before I screwed it in.
As for grinding down the end of the mill, I think it would likely twist off, since it's some sort of weak assed cast metal.
Plus add a nut to lock it down.. screw the bolt to the end, then back off half a turn, and lock it in.. used my for the past 2 yrs setup as such, with no issue bolt wise.. I've also added a brass shin of .010 thickness in the shaft end to cut down on the ware.. also don't try to grind down all in one or two pass, I grind my in four passes..Appalachia-Shiner wrote:did coat the threads liberty with Anti Seize before I screwed it in
Mars
– Albert Einstein
– Albert Einstein
- MichiganCornhusker
Put the bolt into the corona with a jam nut on it. Thread the bolt in until it bottoms out, back it up half a turn, then hold and tighten the jam nut against the shaft.
This is what I do and when the grade 5 bolt snaps, it snaps at the nut. Loosen the nut and the broken part of the bolt comes right out.
The reason I haven't gone to a grade 8 bolt is that I'm afraid that if the bolt doesn't break the shaft will.
I don't grind too hard, preferring to do several lighter passes rather than a few real torquers, so it doesn't break that often any more.
edit: posted with StillerBoy, we are apparently on the same page!
See above ... the bolt has stripped the internal threads of the auger. As is the auger is bound for the recycling bin so, absent some other fix, I'll try grinding down the end since I've nothing to lose. Meanwhile I'm looking at the Millar Mill "Pilot." Expensive but apparently it will do corn.
________________
If it was me, I would try this first.. drill out the present thread space for the next thread tap size up.. who known, it may just work out.. and apply what was presented to you here and see what happens..greggn wrote:I stripped the threads in the auger on my second (this afternoon).
Mars
– Albert Einstein
– Albert Einstein
Heli coil is a great idea.
Pretty sure mine takes a 5/16 bolt, if you drill it out and tap for 3/8 the bolt head might be too big for drill.
as far as bolts go when I'm doing something similar, I cut the head off the bolt
and mill 3 flats on the shank about an inch long. better grip and support for
your chuck than a bolt head.
Not familiar with the engineering (or any engineering much) but if you insert a shear bolt you might save yourself a lot of trouble with breakages in the main works.
- Truckinbutch
This is the best advice I've seen in one post .MichiganCornhusker wrote:Put the bolt into the corona with a jam nut on it. Thread the bolt in until it bottoms out, back it up half a turn, then hold and tighten the jam nut against the shaft.
I do the same and MCH's setup and procedure are very similar to mine .
Every post has added a bit of useful info .
Over drilling and rethreading the bore should work . Leave the bolt head on and chuck a socket adapter into the drill and just add the appropriate socket . That also gives you some leeway with drive alignment issues .
I've had my best success with a 1/2" 9 amp drill . $ 79 at Lowe's . First drill was 6 amp and it just couldn't stand long runs without overheating . Long run being 50# of corn on one pass .
I like the idea of retapping the hole to a bigger bolt size and cutting the head off, putting 3 flats on it.
And running a few more passes on it.
All great ideas there!!!
While there were several good ideas presented they all required tools that I do not own. So, with nothing more than a Dremel and a grinding wheel I put some flats on the auger and fitted a 5/8 socket onto the end. It works well enough to grind barley ... I'll test it on wheat and corn in the coming days.
While I don't expect it to become an heirloom piece that I pass on to my son it does breath new life into an otherwise throw-away part.
________________
if that wears out there are parts online.
Glad to see you got it back in service.
- Truckinbutch
Good fix if the cast iron is of good enough quality to stand the strain . If the shaft fails it may be more cost effective to buy another and save what you have for parts .
I've considered some elaborate machine shop tuning for mine with the rather advanced machines that I have . Not really worth it for such a cheaply replaced grinder .
Lots of good info on those mills here https://www.homebrewtalk.com/forum/thre ... ion.90849/" onclick="window.open(this.href);return false;" rel="nofollow
> Good fix if the cast iron is of good enough quality to stand the strain.
It was good enough to grind barley but corn caused the socket to slip and that galled the auger. Oh well, I got a few more runs from something that was broken and otherwise unusable.
________________
