How much corn/water in beverage cooler?
pickled
Post by pickled » Mon Jun 01, 2020 6:52 am
All grain brewer here.
Looking to make a Booner Casual Corn mash @ 1.8lbs/gallon. I'm unsure how much corn/water mixture will fit in my 10 gallon home depot beverage cooler mash tun. Anyone know? I'd rather not guess and check.
8Ball
Re: How much corn/water in beverage cooler?
Post by 8Ball » Mon Jun 01, 2020 7:05 am
16 pounds of grain & 7 gallons water make it up to the 8 Gallon mark on on my 10G cooler. Works great.
The struggle is real and this rabbit hole just got interesting.
pickled
Post by pickled » Mon Jun 01, 2020 7:07 am
Thanks!
Do you do a sparge?
seabass
Post by seabass » Mon Jun 01, 2020 7:30 am
I've used these calculators with good results over the years. Specifically the "can you mash it" calculator. Give it your mash water volume and grain weight and it tells you the volume you need.
https://www.rackers.org/calcs.shtml
zapata
Post by zapata » Mon Jun 01, 2020 5:18 pm
2nd the mash calcs, always worked for me too.
8Ball
Post by 8Ball » Mon Jun 01, 2020 7:32 pm
Thanks!
Do you do a sparge?
Nope. Ferment on the grain.
pickled
Post by pickled » Tue Jun 02, 2020 8:13 am
This did not go well.
I closely followed Booner's All Corn, with the exception of adding Amylase at 155* and Glucosmase at 130* (generic enzymes).
I filled my 10G mash tun with corn/water mixture and let it sit overnight with the enzymes. I ended up with about 4G of 1.030 wort. It was a pain in the ass to try to drain the mashtun through the metal mesh tube.
Even if I fermented on the grain, I didnt get acceptable extraction/conversion.
JD1972
Post by JD1972 » Thu Jul 16, 2020 12:50 pm
Did you use sebstar HTL first @ 185 degrees?
tombombadil
Post by tombombadil » Fri Jul 17, 2020 4:26 pm
How thick did it get before you added the alpha enzyme? If it didn't turn in to an unmanageable mess then you likely did not get good gelatinization.
Don't give up. I didn't have much success until my third attempt with corn.
