Hasanyone used this??
If it plugs in, post it here.
Skid20
Post by Skid20 »
Ive almost got all the parts and pieces to start my still build. Im using the Auberins PID and was wondering if anyone has used this one and if you did, did you use the thermocouple for temp control or something else. Thanks for any and all input. Great site! I have learned an immense amount!
Always trying always learning
http://www.auberins.com/index.php?main_ ... cts_id=559" onclick="window.open(this.href);return false;" rel="nofollow
Re: Hasanyone used this??
Discussed here: http://homedistiller.org/forum/viewtopi ... 85&t=59470
ps - another link you might like: http://ww.homedistiller.org/forum/viewt ... =2&t=24449" onclick="window.open(this.href);return false;" rel="nofollow
eodstads
Post by eodstads »
I thought about it but ended up buying Auber's SSVR instead with the amperage readout. I have PID's on my home brew setup but I felt that level of automation for the still was largely not necessary because I'm not using temperatures as a definite indicator of process steps.
skow69
Post by skow69 »
It looks like it would work as advertised IF:
1. You had a wash that was always the same and you had run it many times in the same still so you knew exactly how it would behave AND
2. You were satisfied with making cuts by temperature.
IMHO that's no way to make good liquor. I wouldn't use it.
