10,000w SCR vs SSR
Re: 10,000w SCR vs SSR
Oh yeah i remember you saying that now. Lol that sucks. Have you tried the controller out on your pot yet?
When I get some spare time I will open mine back up but it looks like you guys are making out alright. It gets tight in the box. I wish my main fan stayed running even after hitting the on/off switch. When open it back up might look back into that. Also could use better groumets for the wires going into the box.
I used this one I guess that one you listed is similar.Snackson wrote:https://www.amazon.com/gp/aw/d/B002MPPT ... th=1&psc=1
https://www.amazon.com/dp/B002MPQ51O/re ... eMFIjUEnKW" onclick="window.open(this.href);return false;" rel="nofollow
Thanks ddizzle.
What size fan are y'all using? How many cfm is enough? Thickness shouldn't really matter should it?
Mine was super tight as I mounted everything to the lid.
Yesterday was a crappy day so I did t get anything done. Have not used yet still have to add the main power.
Today. Will do it today and hope to do my cleaning runs this weekend
Look good? No incoming or outgoing cable yet. This is the leviton 30amp switch from home depot. I'll add the120 fan when gets here.
I got the mains made but didn't have time to get lock nuts for the cable glands. Try to get them tonight
[quote="pointhunter75"]Thanks ddizzle.
https://www.amazon.com/dp/B019W9WU0W/re ... ZQUziFm3sw" onclick="window.open(this.href);return false;" rel="nofollow
That is the fan I used. It's 240v hooked right up in. Fits our box perfect.
No longer available...imagine that! Had like 7 yesterday I was looking.ddizzle22 wrote:pointhunter75 wrote:Thanks ddizzle.
This one is: https://www.amazon.com/Uxcell-Plastic-V ... 3F82MRF3KW" onclick="window.open(this.href);return false;" rel="nofollowpointhunter75 wrote:No longer available...imagine that! Had like 7 yesterday I was looking.ddizzle22 wrote:pointhunter75 wrote:What size fan are y'all using?
still_stirrin wrote:This one is: https://www.amazon.com/Uxcell-Plastic-V ... 3F82MRF3KW" onclick="window.open(this.href);return false;" rel="nofollowpointhunter75 wrote:No longer available...imagine that! Had like 7 yesterday I was looking.ddizzle22 wrote:pointhunter75 wrote:What size fan are y'all using?
Stirrin, that one says once available and usually ships in 1to2months
Mine is 92x92
What about ordering from Walmart then? https://www.walmart.com/ip/220VAC-0-07A ... =sem#about" onclick="window.open(this.href);return false;" rel="nofollowpointhunter75 wrote:Stirrin, that one says once available and usually ships in 1to2months
Was about to order but it said arrival feb 15 lol I'll Look around some more later today. So far all on eBay ship from Hong Kong.still_stirrin wrote:What about ordering from Walmart then? https://www.walmart.com/ip/220VAC-0-07A ... =sem#about" onclick="window.open(this.href);return false;" rel="nofollowpointhunter75 wrote:Stirrin, that one says once available and usually ships in 1to2months
I am having trouble getting Amazon to open here at work, but I got mine for about $12 shipped with Prime.
Took 2 days to get here
I will link it when I get home
https://www.amazon.com/gp/product/B019W ... UTF8&psc=1" onclick="window.open(this.href);return false;" rel="nofollow
TXB
TXB
TxBrewing wrote:I am having trouble getting Amazon to open here at work, but I got mine for about $12 shipped with Prime.
TXB
That one says in stock Feb 2 lol seems they're All sold out
All I can find in stock on Amazon are the 120v fans. I think im just gonna get one of those. No reason not to right?
Can you wire it up at 110?
Yeah I reckon you just use the neutral and hot wireTxBrewing wrote:Can you wire it up at 110?
Yes, as long as your wiring is four wire so it has a true insulated Neutral and not just a bare Ground... The 240V circuit I use is only 10-3, not 10-4, so it doesn't have Neutral which requires me to run another cord to a standard 120V outlet to power my fan...pointhunter75 wrote:Yeah I reckon you just use the neutral and hot wireTxBrewing wrote:Can you wire it up at 110?
I'm using 10-4rad14701 wrote:Yes, as long as your wiring is four wire so it has a true insulated Neutral and not just a bare Ground... The 240V circuit I use is only 10-3, not 10-4, so it doesn't have Neutral which requires me to run another cord to a standard 120V outlet to power my fan...pointhunter75 wrote:Yeah I reckon you just use the neutral and hot wireTxBrewing wrote:Can you wire it up at 110?
So, I got it all wired up and when i flipped the switch, nothin happened...
So, that got me to troubleshooting, I used 10/3 to wire the box, and the grounds all tie into each other
The ground from the wall, the ground to the SCR, and the ground to the element.
This means that unless the element is installed into the keg and plugged into the controller there is no ground..correct???
So this is why it the fan will not turn on when I flip the switch.
Is this going to be an issue???
TXB
TXB
Everything should be properly grounded all the time and not dependent on having the element plugged into the controller... Anytime there is electricity available there should be a working ground... Also, your fan should not rely on ground, it should be connected to either one of the hots and neutral... Very few fans have an actual ground...TxBrewing wrote:So, I got it all wired up and when i flipped the switch, nothin happened...
TXB
I know earlier in the thread, they said it must have a load on it. Not sure if they meant for the meter to work or the scr.
SCR's require a load in order for the circuit to be activated... Virtually all solid state relays only control one of the mains... Even if the other is wired through the unit it is simply a pass-through... So if a load isn't connected, the circuit is not complete... Therefore the ammeter probably wouldn't work either but a voltage meter would as most (at least digitals) need to be wired into the mains before the controller... I take analog voltage readings at the element...pointhunter75 wrote:I know earlier in the thread, they said it must have a load on it. Not sure if meant the meter or the scr.
Thanks for that info rad
The fan is 220 so it is wired straight to the switch.rad14701 wrote:Everything should be properly grounded all the time and not dependent on having the element plugged into the controller... Anytime there is electricity available there should be a working ground... Also, your fan should not rely on ground, it should be connected to either one of the hots and neutral... Very few fans have an actual ground...TxBrewing wrote:So, I got it all wired up and when i flipped the switch, nothin happened...
TXB
I need to look
But I might have thought of the problem
Yep
Forgot to tie the ground to the switch itself
Fan works now so that circuit is good
Filling the keg now to see if the element will fire
She is good to go
Cleaning runs this weekend
And prep a sugarhead for sac run
[quote="TxBrewing"]She is good to go
Wish I was at that point !!! Are you wiring directly to keg? I want to put a plug on my keg but haven't figured Out exactly how i want to do it.
