newbie question ( heating element buzzing)
If it plugs in, post it here.
huxley
Post by huxley »
I tried my still the other day, first time using the heating element and electric controller. from 1 to 6 on the controller is fine but after 6 the heating element starts a buzzing noise, then stops at 9 on the controller (at max)
setup is 8 gallon, 110V Heater Controller with 2000 Watt Element & Boiler Adapter
wondering if that is normal
thanks
HDNB
Re: newbie question ( heating element buzzing)
Post by HDNB »
the element in the kettle? or is the buzz from the controller?
can't say as i have ever heard of the possibility of the element making noise. weird. if it is the element, i'd like to see (hear) video evidence so i know what to listen for.
now i drink for evil.
Still Life
Post by Still Life »
Heater belts will buzz when fully powered. It's a physics thing, but usually only perceptible and not obnoxious or sign of failure.
Control panel buzzing usually means imminent load (heater) failure, and not necessarily control panel fault.
Can't speak for elements.
Aussiedownunder01
Post by Aussiedownunder01 »
My heaters make a noise when I have my hearing aids in other wise nothing :think:
yakattack
Post by yakattack »
With the element under load it will make some noise. This isn't so much the element itself, but rather the element flash boiling the liquid directly in contact with the element.
If this is the noise you are hearing, it should subside or stop altogether as soon as your boiler comes to temp.
If this isn't what you are hearing, then you will need to do as hdnb suggested and get a small video of it so we can hear it.
Yak
Pikey
Post by Pikey »
Buzzing will be down to vibration. Our hearing is confined to low fairly frequencies and the range gets smaller as we age (see the member with the hearing aids). Depending on the way your power supply works, it is probably based on a "chopper" of some sort and I suspect it will be the frequency of the switching which is the frequency you are hearing. Which particular element of your circuit is acting as a "speaker" I can't say. However, annoying t may be, dangerous - I don't think so - can you muffle it somehow ?
RedwoodHillBilly
Post by RedwoodHillBilly »
Also, check that the element isn't actually touching the boiler. If your element port is low in the boiler and you are using a foldback or ripple element, it could be touching the bottom of the boiler coupling the switching noise to the boiler. If this is the case, try rotating the element so it doesn't touch.
Buzzing electric circuits usually means something is loose. It could be the element, or even the resistive coil inside the element case. Or, it could be in the circuit board elements, such as a noisy capacitor. In any case, the noise will end when the circuit fails...whenever that is. Bargain components can often be the source.
But the bottomline is..."use it till you lose it"...whenever that is.
masonsjax
Post by masonsjax »
Both of mine buzz for a while too. It stops as the temperature comes​ up.
Pikey
Post by Pikey »
You Say the element is buzzing at high but not maximum power ? This must be caused by movement or flexing. Have you tried Holding the element or pressing gently with a stick or something to see if that stops it ?
greggn
Post by greggn »
I would suggest ... "always have a backup."
________________
greggn wrote:
still_stirrin wrote:...But the bottomline is..."use it till you lose it"
:thumbup:
If the element is buzzing, which it is, definitely get a replacement asap for when this one "gives up the ghost".
BDF
Post by BDF »
If its a 60hz hum (same frequency as you'd hear from a florescent bulb) I wouldn't worry too much about it, as long as your current draw is as expected, and no breakers are tripping. The sound in an of itself isn't sufficient to worry sans any other symptoms like overheating controllers or tripping breakers.
huxley
Post by huxley »
thanks for everyone's advise. no, the element isn't a wavy one, just a straight one, and it doesnt touch the tank. and the buzzing is more like one member suggested. More of an electrical buzzing of a light bulb. and good advise about , I should get a backup element in case this one breaks.
I'll try it again with just water while the still is open , just to see if there's any vibration or not, but I didn't feel anything vibration from the tank last time, but I'll check again.
Thanks everyone . I appreciate it a lot.
yakattack
Post by yakattack »
So funny story.
I was making a run last night, and had just plugged in my controller, and turned the controller on. And wouldn't you know it, from about 55 prcent to 90 percent, my element was buzzing( like a light) soon as the controller hit 100% it stopped, and at which point I could hear the element flash boiling the water.
I'm guessing most people don't notice it even if theirs does it because we tend to usually heat up quick and then dial back. At which point the still will be making enough noise to mask the hum from the element if it's run at that range.
huxley
Post by huxley »
yakattack wrote:So funny story.
thanks for the info.
papapro
Post by papapro »
I just read this thread so this could be a bit late .... from I am getting you use an electronic controller if that is the case I will answer your question. the electronic controllers use devices caled triacs which controll the sine wave of the ower at the lower power/ settings there is a lot of sinewave cut of so the element in the biler is not over powered that is why yo can not hear it at the middle there could be 20 to 24 % os sinewave cut off so there is some kind of fast knocking/ buzzing sound butat the full power 100 % of sinewave is poassed to the load so it is smooth.
Do not warry of that sound it is normal check if any components on the contrller are overheating.
Regards PapaPro
Yes I am a Novice with 40+ years of doing this hobby
distilling is like sex the slower the better and everyone is happy
fermenting is opposit to sex the faster the better
