Keg heater
Keg heater
I have a 15.5 gl sanke and a 1500w element from a Mecco Smoker. If I attach the burner to the bottom of the keg and plug the vent holes could I get good results? Should I look for a larger element?
Re: Keg heater
I run a 15 gal with a 1500w water heater element and can finish a run in 3-4 hours. But I use a second 1500w external band heater to get everything started first and with both running it takes at least ~90 minutes before collection starts even wrapping the whole still in a blanket to minimize heat loss. Your 1500w by itself might take forever to get started. I could probably use both through the whole run but I'd rather keep the process from burping or running away. (I do have a controller but rarely use it)
Re: Keg heater
My first boiler was two 1500w elements on a 15.5 gallon sanke. And I can tell you that heating a full fill was painfully slow. About 2 hours to get to temp and hours more for a spirit or strip run.
Do yourself a favor and get. 5500w element and save yourself from endless boredom.
_____________________
EXPAT
Current boiler and pot head
Cross flow condenser
Modular 3" Boka - pics tbd
___________________
EXPAT
___________________
- Hoosier Shine9
Re: Keg heater
+1ExpatLad wrote:My first boiler was two 1500w elements on a 15.5 gallon sanke. And I can tell you that heating a full fill was painfully slow. About 2 hours to get to temp and hours more for a spirit or strip run.
I have a 4500w with controller in a 15.5 gallon keg.
normal charge is about 12 gallons.
From the time I charge the still & turn it on until I am finished with the run is about 4 hours.
I fill the boiler, turn controller to FULL power.
While it starts to warm I put column on & clamp, Attach pre-condenser & condenser with clamp, Attach water supply & drain line to pre-condenser & condenser..
by then, (10-15 minutes) boiler vapor temp is about 80f-85f.
I turn water to pre-condenser on when boiler vapor temp gets to about 140.
About 25-30 minutes later boiler vapor temp is about 160f, column is starting to get warm.
Start turning the controller down.
in the next 10-15 minutes column is about 180f and in full reflux. HOLD FULL reflux for about 30 minutes. get controller turned down to about 2/3 power
Then turn down water to pre-condenser, turn water up to condenser, take off FORES (about 10-12oz) then start collecting in 1/2 pint jars.
I collect at a rate of about 6min per 1/2pint, (12min per pint, 24min per quart, 96min(1h36m) per gallon).
normally get about 12 pints total (12 *12=144, 144/60=2h25m).
turn off power 3 1/2 to 4 hours after turning it on.
***edit for spelling***
- Windy City
Re: Keg heater
If you use that element below your keg I am not sure it will ever get hot enough.
Most (if not all) people that have switched to electric and are using a keg use some form of immersion element.
This will require you to drill a hole in your keg near the bottom, and then weld or solder whatever kind of fitting you decide to mount your element.
My preference is a 2" tri-clamp ferrule and a element adapter from Brewers Hardware.
https://www.brewershardware.com/2-Tri-C ... apter.html" onclick="window.open(this.href);return false;" rel="nofollow
- Oldvine Zin
Re: Keg heater
+1 to that and a 5500 watt element like this http://www.theelectricbrewery.com/stain ... ng-element" onclick="window.open(this.href);return false;" rel="nofollowWindy City wrote:If you use that element below your keg I am not sure it will ever get hot enough.
be safe
OVZ
- Oldvine Zin
Re: Keg heater
+1 on the 5500w but heat it up slow if you are going for flavors - crank it for neutralsExpatLad wrote:My first boiler was two 1500w elements on a 15.5 gallon sanke. And I can tell you that heating a full fill was painfully slow. About 2 hours to get to temp and hours more for a spirit or strip run.
OVZ
- Old Man Bakke
Re: Keg heater
Id be interested in seeing some designs on how people are going about controlling all this heat. At 5.5kw of heat that leads me to believe that's going to require a 240v plug/circuit. I cant see anyone pulling that many amps on a few branch circuits in their house. Hear a lot of talk on variac controlled stuff but have yet to find something actually describing how one goes about building something like that.
"If you look down at me you'll see a fool; if you look up at me you'll see a god; if you look straight at me you'll see yourself"....C.manson
Re: Keg heater
You must not be lookin, plenty of its well documented.
We have a whole forum dedicated to electric
viewforum.php?f=85
But yes, 240 and a controller is by far the most common approach. And assuming USA, a 30 amp circuit is probably the most commonly used, pretty much every house has one for an electric drier.
viewforum.php?f=85
Re: Keg heater
+1 for the 5500W heating element.
At 15o0W, your element that would not even be in direct contact with the mash means a low efficiency and may be you won't even be able to reach boiling point.
