gas burner
gas burner
I have an old rusty burner. It used to give a strong blue flame, but recently it's an ugly yellow flame with lots of soot, I get a layer carbon on my pot.
Can that be due to difference between propane and butane? (I don't know what I used before and should check what I use now)
Other possibilities would be the pressure regulating thing (no idea what it's name is) or the burner even more rusty then it already was (and blocking an oxigen inlet?
thanks
thanks
-I have too much blood in my alcohol system-
lol, not rusty at all, if you have the regulator figured out for sure, see if you can dimantel the end where the hose goes in, should be a very small orfic there, make sure it is good and clean and blow compressed air from the burner ring back to where the hose connects when you get it apart, like they said, where glasses, you will be amazed what comes out of there.
The day you quit learning something new is the day you die. And, if you don't die, then you might as well.
Yes if got heavy rust juts heat rust with torch it will pop like pop corn
just let cool slow it is old welders trick then brush off and oil
like i said if you like cast iron cook ware find in yard sale put in fire
like outdoor fire place leave until all cool remove wash and it will be like
new ps do not use soap on cast cook ware wipe down with cooking oil
A little off topic, but couldn't resist. Dnderhead, you may just be kin. Just like new, will need to be seasoned again if you plan to fry them there taters.Dnderhead wrote:Yif you like cast iron cook ware find in yard sale put in fire
S'what I thought. My definition of "rusty" is "kick it once and pieces start to flake off"...arkansas wrote:lol, not rusty at all
"If you can't dazzle them with brilliance... baffle them with bullshit."
"Don't steal. The government hates competition."
"Believe none of what you hear, and only half of what you see"
20lt small pot still, working on keg
