Oooops...Need Advice Operating My 3" Copper Dephlegmator
- Rain Distillate
Re: Oooops...Need Advice Operating My 3" Copper Dephlegmator
While cleaning up after the flood I realized the flame went out. Re-Lit without dephleg and have a steady drip. Can't seem to hold a steady drip/ can't seem to run the dephleg while producing without causing the flood.
- Rain Distillate
https://www.youtube.com/watch?v=727Irf_9J-c" onclick="window.open(this.href);return false;" rel="nofollow
heres what it was doing when running dephleg and collecting distillate.
- Rain Distillate
FreeMountainHermit wrote:Check your dephlag output cooling line to see if the flow is fluctuating .
After that last flood I'm afraid of even turning it back on til the hearts come through.
- Rain Distillate
If it is indeed fluctuating then what you think the problem is?
- FreeMountainHermit
Wild guess would be pressure variation. Are you running off a well ?
Blah, blah, blah,........
- MichiganCornhusker
Something is wrong. That's what I say.
I never have run a deflag, but your problem isn't with operational tweaks, I'd say something more basic is broken.
Maybe deflag has a cracked joint somewhere allowing cooling water into column.
Maybe your heat is surging.
Maybe not enough water through deflag and its boiling.
Maybe somebody is flushing the toilet just to screw with it.
I'd say something is broke.
But I don't know.
But I don't know.
- Oldvine Zin
With that low abv output, my guess is a pin hole leak in your rc
OVZ
OVZ
- rgreen2002
This will happen to me when I run my 4" flute. I cannot really figure it out. My best guess is that the way the inlet/outlet are for the dephleg, it never really fills up. Thereis is always a little air in the dephleg. This will allow fluctuation within the dephleg itself that can show up as surging( OK that's what I call it.) where you get a quick pulse of stream followed by slow stream. I have run inlet from the top and the bottom and have still seen the issue so I am not helping the problem as much as lending support
Posted with OVZ... and agree that a small leak can cause issues.
HD Glossary - Open this
- Rain Distillate
Yes I'm running off a well. I bought a hose pressure regulator, thought it would help.
Something broken...hmm..I'll have to look upon disassembly. If I just put it in reflux for 20 mins then shut it off, my proof goes up some and I don't run into the flooding problem. However if I try to collect AND run dephleg, I flood. Very frustrating
- Rain Distillate
I'll look for a leak when it's torn down.rgreen2002 wrote:This will happen to me when I run my 4" flute. I cannot really figure it out. My best guess is that the way the inlet/outlet are for the dephleg, it never really fills up. Thereis is always a little air in the dephleg. This will allow fluctuation within the dephleg itself that can show up as surging( OK that's what I call it.) where you get a quick pulse of stream followed by slow stream. I have run inlet from the top and the bottom and have still seen the issue so I am not helping the problem as much as lending support
Good to know I'm not the only one experiencing this.
I don't know what that screen is about, but it would be my first suspect.
[quote="rain distillate"] Could it be my new s.s. mesh screen I installed? Its a lot higher micron then I would have liked i think 100. /quote]
Where did you install a 100 micron screen? Is this what you are using for packing?
Edit:posted same time as Skow
Using Google Search
Using Google Search
- Rain Distillate
Hound Dog wrote:rain distillate wrote: Could it be my new s.s. mesh screen I installed? Its a lot higher micron then I would have liked i think 100. /quote]
I installed it 18" up the column from the boiler. I use the screen to keep the ceramic rings from falling into the boiler.
Lots of folks bought Shelby AC Cobras back in the '60s and never lived to pay 'em off.
I don't think that's off topic.
Shut 'er down, man.
Shut 'er down, man.
- Rain Distillate
I put it into reflux again. output water pressure does not seem to be fluctuating. Do I dare risk another flood and try to collect in 15 mins with dephleg active?
- Rain Distillate
Its a ptfe gasket with a s.s. screen inside the middle.skow69 wrote:I don't know what that screen is about, but it would be my first suspect.
- Rain Distillate
If its internal how do I check it now?
If you have a fine mesh screen (like 100 micron) under your packing, your column is not draining back into the boiler. It is just filling up and flooding out the takeoff. The proof is dropping because there is no reflux just a column filling up. Look at this thread to see what you should have in there. The very first example is about as tight a micro mesh as you should have.
http://ww.homedistiller.org/forum/viewt ... =2&t=50707" onclick="window.open(this.href);return false;" rel="nofollow
As or checking now, shut your still down, let it cool, take off your column and look. You would really benefit from a sight glass above your packing to see what is going on.
Using Google Search
Using Google Search
- Rain Distillate
Now we're getting somewhere. That makes sense!!Hound Dog wrote:If you have a fine mesh screen (like 100 micron) under your packing, your column is not draining back into the boiler. It is just filling up and flooding out the takeoff. The proof is dropping because there is no reflux just a column filling up. Look at this thread to see what you should have in there. The very first example is about as tight a micro mesh as you should have.
That screen acts like a perferated place in a plated column, just with a lot more reflux coming down on it. So with the vapor pushing up, nothing is draining back. Hence, the flood.
Using Google Search
Using Google Search
- Rain Distillate
rain distillate wrote:Now we're getting somewhere. That makes sense!!Hound Dog wrote:If you have a fine mesh screen (like 100 micron) under your packing, your column is not draining back into the boiler. It is just filling up and flooding out the takeoff. The proof is dropping because there is no reflux just a column filling up. Look at this thread to see what you should have in there. The very first example is about as tight a micro mesh as you should have.
You hit the nail on the head. It's gotta be the screen. That would explain the surge and the flood. It would fill up the column, reach dephleg, dephleg couldn't keep up so it surpassed it and made it up over the top to the condenser. While continuing to fill it would eventually flood.
And all the while the fine screen is filling up with debris becoming more of a plug than a plate.
Youse kin pay us later !!!! We trust ya.rain distillate wrote:rain distillate wrote:Now we're getting somewhere. That makes sense!!Hound Dog wrote:If you have a fine mesh screen (like 100 micron) under your packing, your column is not draining back into the boiler. It is just filling up and flooding out the takeoff. The proof is dropping because there is no reflux just a column filling up. Look at this thread to see what you should have in there. The very first example is about as tight a micro mesh as you should have.
You got it. Except the dephleg IS keeping up. It's doing its job and condensing the vapor that is not returning back down the column causing you to flood. Once you get a proper retainer, fill your column all the way with the same packing. Run full water to your dephleg and turn the heat up. If nothing comes out while at full boil, you are in full reflux. Let this go for a while then gradually cut back your water flow until you get a slight drip coming out. Then cut a bit more and fiddle with it. By Managing the Coolant you will vary the takeoff. i.e. a C (coolant) M (management) still.
Using Google Search
Using Google Search
- Rain Distillate
I believe I would have successfully used the dephleg with product coming out had I had a better retainer. My process and steps taken were right. If I got enough sheet copper left I'll rig up something to hold the packing up.
- Oldvine Zin
not sure what your flood was because you said cleaning up after. flooded column or just a mess on the output side??
OVZ
OVZ
Half a scrubbie will do the job, man.rain distillate wrote:I believe I would have successfully used the dephleg with product coming out had I had a better retainer. My process and steps taken were right. If I got enough sheet copper left I'll rig up something to hold the packing up.
- Rain Distillate
The column flooded because of my retainer apparently. then once full, it shot out the output. Very dangerous. will NOT be running it again like that.Oldvine Zin wrote:not sure what your flood was because you said cleaning up after. flooded column or just a mess on the output side??
OVZ
- Rain Distillate
Think I could just cut or drill a bunch of decent size holes in the s.s. mesh on the gasket?? I stand corrected it's 150 micron ooops.
