Copper Scrubber Replacement How Often?
Still Life
Post by Still Life »
<Can't find a suitable answer.>
I'm sure Still_Stirrin will, and blast me...
Running a pot still currently.
But got a new CM still coming (building is out of the question) and I'm wondering how often the copper scrubbers have to be replaced.
Do you go by so many runs, or when they start turning blue, or how do you do it?
Talking Brewhaus copper pads, so purity's not an issue.
I will be distilling every weekend and just want to know so I can stock up appropriately without having to damn stop over this.
Thanks, good folks.
Euphoria
Re: Copper Scrubber Replacement How Often?
Post by Euphoria »
If you clean them by soaking them in a Citric Acid solution after each use, they'll clean right up. Take care of them and you can reuse them for years.
Still Life
Thank you, Euphoria. Will do.
Still Life wrote:<Can't find a suitable answer.>
Ha! That's funny stuff right there. Is your "sittin' down spot" a little sore?
Still Life wrote:I'm wondering how often the copper scrubbers have to be replaced.
If they start to look black or your product is starting to stink more, then you should service them. If they're real copper, an acid wash and water rinse, followed by an air drying should be adequate. If they've lost a lot of mass or they have become "crumbly", then they should be replaced. But by then I'm sure you'll have plenty of time to acquire replacements.
Personally, I use glass marbles (and I know where they all are).
StillerBoy
Post by StillerBoy »
Euphoria wrote:If you clean them by soaking them in a Citric Acid solution after each use, they'll clean right up. Take care of them and you can reuse them for years.
Yes citric acid bath after using them helps clean them up, but you also need give them an baking soda bath to neutralize the acid, then allow to air dry, don't repack them.. otherwise just a water rinse will not stop the acid from working unless neutralized.. by neutralizing you will extent the life of your copper srubbers.. a vinegar wash will also clean them up, just not as quickly, and with vinegar a water rinse is good to go..
Mars
– Albert Einstein
Still Life
Nope. But you ARE keeping me researching before I dare post a question.
Just poking the bear.
Appreciate the answers, everyone.
Citric & baking soda. Got 'em.
Can't wait for the new still, and willing to take on the challenge of a CM.
Wish DAD300 was still hanging around. Learned a lot of CM operation from reading his stuff.
joeymac
Post by joeymac »
I haven't replaced mine in a couple years... I switched to glass marbles and the copper scrubbers have been sitting in an old shoebox ever since. So I can't see a reason to switch the copper scrubbers out for new ones cause they look just the same as they did the day they got put away. :think:
cob
Post by cob »
Seems I read somewhere about some folks putting their scrubbers in their backset and rinsing to clean them up.
could have been this place; http://homedistiller.org/forum/index.php
Still Life
heh! Thanks, cob.
You takin' over for still_stirrin? or Rad?
