Woo Hoo - new pot ?
Woo Hoo - new pot ?
Whaddya think ? - has this got promise ?
The tank is 450mm diameter (18") and useable height is 600mm (24") - which I make to be 96 LItres, or about 26 of your gallons. It is all made of copper, including the lid - I'm very hopeful !
Re: Woo Hoo - new pot ?
Looks old, probably lead in the solder (if indeed it is soldered but to a non-metal worker it looks like it).
I agree !The Baker wrote:Looks old, probably lead in the solder (if indeed it is soldered but to a non-metal worker it looks like it).
So now I'm stuck with cutting the damn thing up and rebuilding it with new solder, or scrapping it ! What a pissser ! But thanks for your observation
Any other ideas ?
Ok, I had thought it would burnish up and become a lovely piece - the bottom as a boiler and the top as a thumper tub. I'm thinking if I cut the clearly defined solder joints out for their full width and replace them with strips cut from the top tub, using lead free I may be able to make it work. I have another, but deliberately went for a really old one since the copper is much thicker. Won't look much, but I'm not bad with a torch and it will give me a chance to fully clean the inside and out. Also to take a good look at the heat exchanger and see what that needs.
Whadya reckon ?
Thanks again Geoff
[edited for spellings]
Whadya reckon ?
Thanks again Geoff
I'd test them first with a lead test kit.
If they are lead, cut them out and just solder it all back up. Only thing is that it will be slightly smaller.
Had a look on ebay - I can only find "Water lead kits" so I don't quite know how to go about testing. I do know those Fortic tanks were 1960's or a little later. this is one of teh earliest I think, so could be even earier - and even in the '70's Plumbers were still "Wiping" Lead joints on drinking water pipes - so I'm not optimistic !xyz123 wrote:I'd test them first with a lead test kit.
But yes, I haven't thrown the baby out with the bathwater yet and was coming to a similar conclusion. More work than I'd hoped, but a chance to really "build my own" too !
I'm hoping to unsolder the seams and clean them up. Has anyone tried this ? I'm pretty sure I can get them hot enough to melt the solder, but I think it will set again as I move my arc along. I have electronic solder wick - but that would ruin masses of wick with the amount I'd need to use. Anyone know of another way of sucking the wet solder off ?
Edit:
- nerdybrewer
Depending on where you live...
Hardware stores carry lead test kits, here are examples:
http://www.homedepot.com/p/3M-LeadCheck ... /203313743" onclick="window.open(this.href);return false;" rel="nofollow
http://www.acehardware.com/product/inde ... 13.1259815" onclick="window.open(this.href);return false;" rel="nofollow
Cranky's spoonfeeding:
I'm going crazy here in uk - ebay will seel me a couple of swabs for £35 or Amazon for £12.99 - but their amazing delivery says they can get it here by Marck 17 ! B&Q, Homebase, Plumb-base don't know what I'm talking about ! - yet you can walk intoany hardware store and buy onenerdybrewer wrote:Depending on where you live...
Thanks for trying
I'm pretty certain though that the solder will be lead based - the thing is c 60 years old !
- nerdybrewer
I've got it pretty good, I have literally lived across the street from a small hardware store for about the past 30 years.Pikey wrote:I'm going crazy here in uk - ebay will seel me a couple of swabs for £35 or Amazon for £12.99 - but their amazing delivery says they can get it here by Marck 17 ! B&Q, Homebase, Plumb-base don't know what I'm talking about ! - yet you can walk intoany hardware store and buy onenerdybrewer wrote:Depending on where you live...
Thanks for trying
I have walked in and bought one of these kits for $10, used it to determine the crap still I bought on eBay had lead solder, sent it back and got a refund.
Then I built my own properly.
nerdybrewer wrote:I've got it pretty good, I have literally lived across the street from a small hardware store for about the past 30 years.Pikey wrote:I'm going crazy here in uk - ebay will seel me a couple of swabs for £35 or Amazon for £12.99 - but their amazing delivery says they can get it here by Marck 17 ! B&Q, Homebase, Plumb-base don't know what I'm talking about ! - yet you can walk intoany hardware store and buy onenerdybrewer wrote:Depending on where you live...
Thanks for trying
Pikey, surely you can get your hands on a lead test kit. Paint test or water tests will work, as you are just trying to detect lead. If it is negative, check the test kit and see what its detection level is, and go from there. If it is positive, you have your answer. I'm thinking of a swab test when I say that, I'm sure others may have better advice on the accuracy/capability of other types of tests.
I think consumerreports.org had some articles on this in the recent past that might prove helpful.
By the way Pikey, the boiler is a score. If it has lead based solder, well, nothing ventured, nothing gained. I'm rooting for you on this one.
Thanks Hank, I'm thinking maybe if I grind a little solder off and stand it in water for a few days I may be able to get enough contamination for the water to leach some out and use a water test (Water tests ARE available) - but then it's just so old I don't think I'd believe it even if it was negative !
Time to clear a space in my garage to get the thing started methinks !
Thanks for that - I've been looking so long I really can't believe it ! Ok so I had to drive a couple of hundred miles to pick it up - but got the whole thing for £32 (about 40 dollars) - and magic, it comes with the free Thumper tub, just the right size for the boiler !Hank Reardon wrote:By the way Pikey, the boiler is a score. If it has lead based solder, well, nothing ventured, nothing gained. I'm rooting for you on this one.
Pikey, I just now seen this thread and man what a great find!
How has it turned out on redoing this beautiful thing you've found?
Things moved on ShineOn.
I managed to score a complete 50 Litre stainless boiler, with a 2" triclamp and electric element, so the impetus has gone out of it. PLus loads of other stuff which is calling for my time, so in honesty, I'm never going to get round to doing anything real with it, so I guess in reality - it's up for sale ! Anyone in the middle (ish) of uk who's interested, can drop me a pm, else I'll advertise it when I get around to it.
Pikey, instead of stripping out the lead solder, could you not cover the seams with strips of copper foil ( you know the copper foil in that pot head you bought lol ) and silver solder it on.
more than one way to skin a cat. as the saying goes,
Nice suggestion Squint, but it's not just the possible lead - I'd love to see it / up and running mate - on some racking - with the big fermenter, then that preheater from another thread - then bottom part of this unit all shiny as a pot, then the top part as a thumper, all of them shiny, coppered up and looking cool, standing in a line Trouble is I just have so much else I'm committed to and I now have a nice stainless pot which is adequate for the job. So I just don't have the incentive any more. If nobody else wants it - I'll probably use the top part to make a thumper at some point, but at the moment it's just taking up space.
Now if someone near me had some oxy-acetylene I could borrow or hire for a couple of days - THAT might drive me to reconsider But it's a forlorne hope I expect.
About the testing of lead: you could do a run with water or alcohol and then test the distillate.
The problem is not in the lead in the solder somewhere in the still, but any lead in the product.
I doubt that leadcontaining molecules will distill with the vapour, but I can imagine lead will leach out in the fluid in the condenser.
Dissolved lead in the spent lees can be a problem too, depending on how you get rid of them.
If you test the distillate and the spent lees, you will know what to do.
If you modify it to build a boiler, that has to be better than building with SS then adding bits of copper to the boiler to emulate the real thing.
BLASPHEMY !Kareltje wrote:About the testing of lead: you could do a run with water or alcohol and then test the distillate.
However I'm not terribly Religious and that sounds like good sense
I know Chris and the thought of those 3 in a row is really sweetNZChris wrote:If you modify it to build a boiler, that has to be better than building with SS then adding bits of copper to the boiler to emulate the real thing.
{Edit - the thing is tho' there's no "build" needed on the stainless one - except doing up tri-clamps and perhaps changing the plug ]
it certainly sounds as though the overwhelming view of the forum is that I should keep it then !
Okay, it's been a while but this is still relevant.
I have an old copper fire extinguisher shell that I may use as a 'whisky helmet'.
It is riveted and probably soldered (okay I am not a metal-worker!)
The top was damaged so I cut it off leaving the inside exposed.
If I heated the inside of the join with a torch the original solder should 'melt off', no?
And then I can solder the join and tin around it with lead-free solder and it should be fine....
