what tri clamp should i also will be using 1.5 copper pipe
would i get the npt furrel or not
not sure which one to buy help please
thanks g
i have a 50l keg
- MichiganCornhusker
Re: i have a 50l keg
Welcome, Gino.
Your first post should be to the Welcome Center to let us get to know you a bit.
If you can post a photo of your keg we can better help you.
I have a 50L keg and it takes the same 2" clamp that I use for my U.S. 15 gallon keg.
so i have posted in the welcome
i cant find the 2in tri clamp to 1.5in copper pipe with the npt fittings ?
i will be using 1.5in pipe 20in long to a 90 then a 5 in to a reducer to 3/4 again 5in to a reducer to 3/8 to my worm.
thanks g
thanks g
Ha, no pic?
There are some good options online for keg connections.
If copper you would just need a reducer to get down to your 1-1/2" size.
so i have got on the way
2in tri clamp to go on mt keg
and 2in furrule to 1.5npt to fit mt 1.5in copper
i will run my old still couple more times befor i am ready
thanks g
now just have to make up my mind on the rest of it
i will post pic shortly
thanks g
