Kick My Ass
Kick My Ass
Ok I'm kicking my ass yes other things in Life have kept me busy but still no excuse!! I've seen numerous times questions about Blue distillate.over the years ..Although no one admits to it ...I've left low wines a little to long sitting on the plates,I'm running a flute but regards no matter what type of system your running it will do the same... should be put out there ...Lesson Learned!!! upon cleaning for the next run which I always do noticed some blues on the copper grrrr...now to get cleaning ,Just glad I do a cleaning before each run and check everything over...
- Still Life
Re: Kick My Ass
Chemistry doing its thing,
But you got a handle on it and know the cure.
Don't break your leg kickin' yer own ass.
Re: Kick My Ass
Last time I was around here... cussing got me in trouble.
Now it's ok.
I like it!!
Now it's ok.
I like it!!
Re: Kick My Ass
Don't get too excited, there, worm. It could get unpopular again just as fast.
- cranky
Re: Kick My Ass
I'm not sure what you mean by cleaning every run. I think of cleaning as scrubbing by hand followed by a vinegar/ water run followed by a water run then a sacrificial run. I only clean if I find a problem, doing too much cleaning can remove the protective patina resulting in corrosion and blue distillate.frost021 wrote:Just glad I do a cleaning before each run
Re: Kick My Ass
too much cleaning makes new blue shit. old dirty copper don't blue up on me either.cranky wrote:I'm not sure what you mean by cleaning every run. I think of cleaning as scrubbing by hand followed by a vinegar/ water run followed by a water run then a sacrificial run. I only clean if I find a problem, doing too much cleaning can remove the protective patina resulting in corrosion and blue distillate.frost021 wrote:Just glad I do a cleaning before each run
now i drink for evil.
Re: Kick My Ass
HDNB wrote:too much cleaning makes new blue shit. old dirty copper don't blue up on me either.cranky wrote:I'm not sure what you mean by cleaning every run. I think of cleaning as scrubbing by hand followed by a vinegar/ water run followed by a water run then a sacrificial run. I only clean if I find a problem, doing too much cleaning can remove the protective patina resulting in corrosion and blue distillate.frost021 wrote:Just glad I do a cleaning before each run
"Mina patina"
Re: Kick My Ass
I may have worded that wrong as not really a cleaning as per scrubbing ect...I usually just check everything over and give it a rinse with water...and make sure all the gaskets are still in good order...and everything is tight before charging..that being said I did do a though cleaning a few runs back...I guess a few lessons learned though don't leave low wines for too long on the plates and shouldn't have done that cleaning ..the ol saying goes not broke don't try and fix itcranky wrote:I'm not sure what you mean by cleaning every run. I think of cleaning as scrubbing by hand followed by a vinegar/ water run followed by a water run then a sacrificial run. I only clean if I find a problem, doing too much cleaning can remove the protective patina resulting in corrosion and blue distillate.frost021 wrote:Just glad I do a cleaning before each run
I didn't realize I was cussing but will be mindful and didn't want to offend anyone
Thanks for the Replys
- cranky
Re: Kick My Ass
Leaving wet plates is a good way to have to redo cleaning runs for sure, I make sure I don't leave mine wet if I can help it.
- Jimy Dee
Re: Kick My Ass
Could some one please tell me where the "cuss" appeared? Also whose ears has the cuss preciously damaged? I just don't get it. JD
Re: Kick My Ass
To you and me Jimy there is no profanity - Although we may feel it a little unfair to go aroung kicking Donkeys !
